1990 Infamous SEAT BELT lite and INFL. RESTR lite problem
![](/forums/images/ranks/500-1000.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
I have a 1990 Vert with 14,000 miles. Started it today and both lites came on and stayed on. Did a search and then checked for codes. No codes showed up with my Auto XRay scanner or the plug in code reader...just kept blinking a code 12. Tomorrow I will start with the sensor on the passenger side to clean (as the search results indicated). The thing that bothers me right now is the fact that in doing the search; codes would be thrown for either left or right side sensor but I show NO CODES. I was able to see the sensors(just barely) and the bolt down area looked clean and no rust but will clean and grease as the search indicates.Am I missing something in my search where NO code is shown and if my preliminary observation on the sensors show no rust...where do I go Next?
I would appreciate any imput into this matter.
Bill
I just retired and have the time to do it but hope for no big $$ cost.
Bill
![EEK!](https://www.corvetteforum.com/forums/images/smilies/eek6.gif)
![](/forums/images/ranks/11k.gif)
Received 3,043 Likes
St. Jude Donor '05
![](https://www.corvetteforum.com/forums/images/ranks/cf15.jpg)
Youre starting in the right place. 90s are notorious for that stupid light coming on all the time.
Wow; since I bought my Vette last year the things that I have learned so far on this forum are Mind Boggling!!!
![Crazy](https://www.corvetteforum.com/forums/images/smilies/crazy.gif)
Thanks to all for the help so far
![Cheers!](https://www.corvetteforum.com/forums/images/smilies/cheers2.gif)
![](/forums/images/ranks/1k-2k.gif)
The A terminal on the ALDL is always the ground. B terminal is what you use to get into the SES, C into the SRC.
So when you ground a paperclip across A-K, you enter the SIR function, INFL RES light will flash and give you the codes that are stored. Nore than likely it will be a 16.
Well I cleaned the RT sensor per instructions...no good...pulled the sensor completely out of vette and checked ohm resistence as per FSM (4 variables) ALL showed okay..the sensor is GOOD
..just for the heck of it I checked with the dealership and not one sensor showed up in North America.After all this I still cant clear code 26. I made an error and was not patient with the error code reading...3 times code 12---3 times code 26 AND a new one..3 times code "41" then back to code 12
!!!!! It looks like the DERM may be the problem or hopefully just a short circuit which possibly affects the code 26 also??.Will look at this tomorrow but I have a disc gone in my back and I didnt retire to hurt more...I may just live with the warning displays as I dont think I want to get under the drivers side dash. Will decide tomorrow I guess.
![BS](https://www.corvetteforum.com/forums/images/smilies/icon_bs.gif)
I have the same problem with my 90 coupe. code 26, last summer I did the sanding thingy, and dialectric grease on the right sensor and then cleared the code. This summer it came back so I cleared the code again. Last week the code 26 appeared again. This time I have been unsuccessful in trying to clear the code. I suspect checking the ohms will indecate a good sensor as well but I have not done that yet. What is the derm and where is it located? This problem is a PITA. By the way when I worked on the sensor there was not a bit of corrosion between it and the frame. Just want to rant a little because of this problem. Have a great day. Allentown Ernie.
![LOL](https://www.corvetteforum.com/forums/images/smilies/lol.gif)
![*****](https://www.corvetteforum.com/forums/images/smilies/willy_nilly.gif)
By the way; thanks for letting me rant also!!!
![](/forums/images/ranks/100-500.gif)
I had the same problem, but instead of going thru all the troubleshooting, I bought a plug/switch from midamerica designs for $20, hooked it up, followed the directions and the lights went away. Don't know what it did, but they're gone.
I made up my own using a small short throw toggle switch. It seems that exact timing is important....3 sec. on---3 sec. off--10 sec on then off. tried and tried probably 2 hours but I think that besides the code 26; I was also throwing a code 41 that may be impairing the code clearing...dont know for sure anymore..down the road Im just going to pull the seatbelt lite bulb and the INFL. REST. BULB AND CALL IT A DAY.
![](/forums/images/ranks/2k-3k.gif)
A code #26 is the right front sensor fault. Sometimes cleaning & sanding won't fix it. But before doing any work on them DISCONNECT THE BATTERY!!! If the codes won't clear then your sensor is faulty. Check the pin connector in the footwell area with an ohm meter on the pins. The factory service manual will tell ya the sequence and ohm specs. Not very often does the DERM go bad. You will need to peel back the carpet in the footwell area to get to the yellow barrel connectors. Let me know I can help some more. Pipe
![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
A code #26 is the right front sensor fault. Sometimes cleaning & sanding won't fix it. But before doing any work on them DISCONNECT THE BATTERY!!! If the codes won't clear then your sensor is faulty. Check the pin connector in the footwell area with an ohm meter on the pins. The factory service manual will tell ya the sequence and ohm specs. Not very often does the DERM go bad. You will need to peel back the carpet in the footwell area to get to the yellow barrel connectors. Let me know I can help some more. Pipe![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
![Ack!](https://www.corvetteforum.com/forums/images/smilies/ack2.gif)
Any help would be appreciated to solve this problem as I have the time now since I retired. I want to walk away from this problem one moment but my stubborness keeps me going to fix it.
Your almost correct 3 variables. 2 at 10,000 ohms and one with less than 1 ohm. A code 41 is indicator lamp circut, shorted to battery or ground.The DERM is a pain in the azz to get to. It's good you are persistent at fixing this problem and not just going to pull the bulb out of the driver info center. I know it's tough getting under that dam dash. Ya gotta be double jointed. This kinda got me stumped as usually it's the sensor. Pipe
Your almost correct 3 variables. 2 at 10,000 ohms and one with less than 1 ohm. A code 41 is indicator lamp circut, shorted to battery or ground.The DERM is a pain in the azz to get to. It's good you are persistent at fixing this problem and not just going to pull the bulb out of the driver info center. I know it's tough getting under that dam dash. Ya gotta be double jointed. This kinda got me stumped as usually it's the sensor. Pipe![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
Thanks for all the help..it kept me going . Will be back when and if I get back to this project.
The left and right sensors have the same part number so I wonder if you could switch the sensors form one side to the other, clear the codes and then see if the problem changes to the left side (code 16). This would indicate a bad sensor. If you get code 26 then I guess the problem is in the wiring from the sensor to the derm or the derm it's self. In any case the results could give you additional clues as the source of the problem. Code 41 seems to be involved with the light once it's on so if could eliminate your code 26 then code 41 might take care of it's self.
Thanks again to all that posted and gave me ideas and advise!!!!
I believe if you're not concerned with the "functionality" of the SIR a 2 ohm resistor at the connector to the bag or at the base of the column will defeat the "bulb on"!
It will also allow the 'belt warning" I believe to funtion properly.
