94 LT1 - Serpentine Belt
![](/forums/images/ranks/1k-2k.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
OK, for the life of me I can't figure this out.
Last time I took the belt off no problem, this time, I can't get the belt off without hitting the water pump temp sensor, or getting my wrench jammed up against the rack after taking the belt off.
What the hell am I doing wrong? What wrench/technique/position do you guys usually attack the tensioner to remove the belt?
(and while I have you here, what size torx wrench do I need to move the alternator / ac compressor out of the way?)
Thanks a million. Going in to attack a power steering leak today...
John
John
![](/forums/images/ranks/4k-5k.gif)
John
John
Yeah, that's what I did last time I think, but last time I had no water pump in the way. This time, if I put a wrench on it from above, when I release the belt and try to let the tension out of the pulley, I'll shear off the water pump sensor housing... Can I take that sensor out of the pump without a gush of fluid coming out?
PITA..
So the correct way (at least what I did) is to put a 5/8 wrench on it with the open end facing out towards the driver side, away from the water pump, and then push down on that wrench using a breaker bar, and quickly slip the belt off hoping you don't slip off the end of the wrench and lose a finger tip.![Smile](https://www.corvetteforum.com/forums/images/smilies/smile5.gif)
![Cheers!](https://www.corvetteforum.com/forums/images/smilies/cheers2.gif)
![](/forums/images/ranks/3k-4k.gif)
Yes, the driver's side. This is a ghetto mechanic style job; you really have to be brutal with the pipe extension. I was surprised I didn't break anything else getting the belt back on!
![LOL](https://www.corvetteforum.com/forums/images/smilies/lol.gif)
just use an offset wrench. This way you will not hit the sensor. 14 or 15mm if I remember.
2 minute job, really.
Do not take out the sensor, that is nutz.....
![](/forums/images/ranks/5k-6k.gif)
St. Jude Donor '05-'06
![I Agree!](https://www.corvetteforum.com/forums/images/smilies/iagree.gif)
PITA..
Go spend a few bucks on an offset wrench set, and it is the easiest job there is on a C4..........far from being a PITA job.
I agreee about not taking the sensor off but the correct size is 16mm. Also is it not crazy that the alternator has three screw/bolts keeping it on and they are all different types?! One was hex screw, one was a standard bolt, and one was a metric bolt. I bought my vette used and maybe the previous owner but different bolts in but if it came from the factory with three different types the WTH!?!
