hella headlights ,worth the money?
![](/forums/images/ranks/100-500.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Hey , anybody switched over to the hella type headlights? if so can you give me your thoughts on them, good or bad. thanks brent317
![EEK!](https://www.corvetteforum.com/forums/images/smilies/eek6.gif)
![](/forums/images/ranks/11k.gif)
![](https://www.corvetteforum.com/forums/images/ranks/veteran_army.png)
Had them on my 92. Was a great upgrade and the glass lenses are cut to provide a much better light pattern over a stock type of bulb.
The stock wiring will handle 100/80 or 100/90W bulbs with no problems and as long as the headlight motors and gears are in good shape, they will handle the small extra weight.
![](/forums/images/ranks/5k-6k.gif)
I put a set of Cibies on my dad's '86 several years ago, and they're fantastic. Anything is better than DOT code lights. I'm sure that Hella's are fine, but I can only vouch for the Cibies. That car has the best headlights of any I've driven until I get my E-codes, which should be this week.
