Easy door panel fix
![](/forums/images/ranks/7k-10k.gif)
![](https://www.corvetteforum.com/forums/images/ranks/veteran_army.png)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
I am slowly but shurely fixing all the little things that are wrong with the 91 I picked up last winter.
Both door panels have pulled away at the rear upper portion of the door. When you close the door they flop.
I saw how to do this here recently but cannot find the post that uses this method.
I bought some brass corner braces at Ace Hardware. 1" X 1/2" in size.
You simply attach them with the 10mm bolt that holds the rear window felt bracket. I used some needle nosed vise grips to hold the bracket up while I attached the corner bracket. Here is what it looks like installed:
![](http://im1.shutterfly.com/media/47a0d800b3127ccefa3e5bbccf2500000030O08AbMmzZk4Ztge3nw8/cC/f%3D0/ps%3D50/r%3D0/rx%3D720/ry%3D480/)
Simply lift the door panel over the bracket. You can easily bend the bracket a bit to make sure it is tall enough.
![](http://im1.shutterfly.com/media/47a0d800b3127ccefa3e08b80ea000000030O08AbMmzZk4Ztge3nw8/cC/f%3D0/ps%3D50/r%3D0/rx%3D720/ry%3D480/)
Finished. Took 10 minutes for both sides.![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
![](/forums/images/ranks/4k-5k.gif)
Great job Ron! So many have devoted time to trying to fix the panel when this mod probly woulda done the trick. If my panel repair gives up I will try this.
