I want a new ECM
![](/forums/images/ranks/100-500.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
I知 tired of fighting the old ECM in my 90 model six-speed TPI Corvette. ![Ack!](https://www.corvetteforum.com/forums/images/smilies/ack2.gif)
So I知 looking for an aftermarket ECM to run the motor. A little background first; Edelbrock intake with big tube runners (yes I know its choking the engine) 383 Stroker, Edelbrock Heads, LT4 cam, longtube headers and dual exhaust with no cats. So far I have narrowed the search to two units; the FAST XFI and the Holley Commander 950.
Which one is the easer one to tune, which one will be the easiest to start the engine with the first time?
Another question; I want to upgrade the intake to Miniram or a Stealth Ram. I know the Miniram will fit under the stock hood, but the Stealth Ram won稚. How have you guys modified your hoods to work with the Stealth Ram? Let痴 see some pictures. Are or there any other suggestion for a new intake?
Thanks![Flag](https://www.corvetteforum.com/forums/images/smilies/patriot.gif)
Steve
Steve
Most people who do the stealthram don't mod the hoods, they mod the stealth ram. There is a thread on here about a DIY stealthram mod that turned out nicely if I remember right.
SuperRam is another option. Offers good torque and pulls to 5300-5500 rpm (don't quote me) on a 350.
![](/forums/images/ranks/5k-6k.gif)
Suggestion on the intake? I went Mini-Ram on the 415 I built for the 86 I had. I had been running siamesed base, aftermarket runners and opened TPI plenum; opened as much as I could with my Makita grinder.
MAN WHAT A DIFFERENCE!! Felt like I'd added a second engine under the hood.
Jake
Jake
![](/forums/images/ranks/2k-3k.gif)
Cruise-In VII Veteran
![](https://www.corvetteforum.com/forums/images/ranks/cf10.jpg)
The best ECM is the one you're going to get the best support for. Neither of those companies internal support is very good. You're going to be relying on the support of the dealer you're buying from. Personally I have an XFI in my car. It works well and I've been using their products since before they were FAST. Lately I been doing a lot with Bigstuff 3 systems. Holley has a couple of new systems out that look interesting. The Commander 950 not being one of them.
![](/forums/images/ranks/3k-4k.gif)
If you have a local shop that sells EFI stuff and they also tune them buy what they support. The best system is the one that everything is tuned well because someone knows how to make that system work. Pay full retail or whatever they ask if below retail and ask if you have a problem would they give you some pointers.. Saving a few hundred bucks through internet shopping is money poorly spent. Not knowing what to do with the new one is the same as not knowing what to do with the old except your wallet is lighter.. For low end systems I am a big fan of a Haltech sport 2000 or a DFI gen VII for a street car or bracket etc.. I am a WD for several systems and given a choice a Motec M800 would be my first best choice with data logging and dual wide band internal to the unit. Saying that it is too expensive for my own C4 I am not going to put 8k in electronics in my 10k car..LOL..
![](/forums/images/ranks/1k-2k.gif)
I agree with STH. Why can't someone make a computer with all new 21st Century processors, software, etc., in the original/stock case? I, myself, have replaced the ECM in my car, with a re-built unit, and am not convinced that this one is running right. Let's face it, at the time my car was made, a desktop computer only had about 100 MEGAbytes of memory, and now they're what, 5 GIGAbytes?
Question: Is a "re-manufactured" ECM a re-progammed unit or has it been completely gutted and new circuitry, processors, etc. added? Does anyone know?
Mike
'90 'vert
Mike
'90 'vert
Download the software for a Motec M800 it is free and the software used to program the system. See what you think about current software after that. It is dual wide band drive by wire traction control onboard data logging and I can set up a correction table for anything.. A simple one would be to change the rev limit vs. engine temp Vs. oil pressure... Boost vs. throttle position the list is endless..
I have a FAST Classic system. The car hasnt been started yet, but it's getting close. We had some issues with the computer, and FAST was able to assist me with those issues.
I am impressed so far with FAST.
I have the opportunity to buy an unused FAST Classic System from a friend who never used it, what is the difference between the older FAST systems and the XFI? Is it easier to tune the newer XFI are is it the same with the older FAST system?
Mike
'90 'vert
Mike
'90 'vert
driveability issues, etc. GMautocomputers.com
They're very similar tuning wise. The XFI has a faster processor with additional features the classic doesn't have. FAST no longer repairs the classic boxes If something goes wrong in the future.
We know, and each computer we reman is tested with original Delphi (The original OEM) test equipment and checked with a master eprom for 40 pass/fail codes and all components are checked and are repired/replaced if needed. The computer is then loaded with the latest GM software for that year and tested again. What you guys don't realize is a 30 year old computer that was only designed for a 5 year life, tends to degrade over time and even if your car is running, it needs to be "reflashed", as GM released updates for each ECM/PCM for 5 YEARS after your car was built. These updates were to correct "field issues" such as speedo correction, mileage issues, hot start problems,
![Frown](https://www.corvetteforum.com/forums/images/smilies/frown5.gif)
We rebuild 2-3 of the 92/93 ECM every WEEK! There will not be an aftermarket ECM for probably any 90's up car due to the amount of time reqired to decode the original software. By 92 there was over 300,000 man hours into writing all the code for an ECM.
