Coolant fan running all the time
![](/forums/images/ranks/5k-6k.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Hi im sitting on the drivers seat of my 87 and its annoying
i put the key in the ON position and the coolant fan starts !
it didnt do this before,migth be related to my AC Delete ???
im checking the connections but everything seems right
help ! im trying to communicate with my engine via aldl with no luck as well,thanks !
![](/forums/images/ranks/2k-3k.gif)
St. Jude Donor '10
![](https://www.corvetteforum.com/forums/images/ranks/cf10.jpg)
This happened to me when I was first playing around with the aldl cable. To reset it I had to actually start the engine and then turn it off again. After that it was OK.
Yes that sounds like it ...reasons ...not sure...
Removed Drivers's side head sensor wiring, fan still work
Removed passengers side head sensor , same thing
i even removed the MAT to see what happened and same thing
i pulled the fan's plug and that obviously make it stop but no sensors are wrong as far as i know its something else ...
i Did a big upgrade but im not sure if the other day the fana was On all the time as well
like five days ago i tried to hook my ALDL cable to datalog with no luck.
im still trying today and no luck.
I installed the Moates adaptor with a new .bin file sent by gregg
but this was happening with the stock chip as well and 2 days ago.
I had started the engine many times
i even have a battery kill switch,so the ECM is always de-energized
![](https://www.corvetteforum.com/forums/images/ranks/cf20.jpg)
you haven't been paying attention in class over all these years.
![Frown](https://www.corvetteforum.com/forums/images/smilies/frown5.gif)
Drv side is a mech switch for Aux fan , pass side is sensor for temp gauge
The ECM is the only thing that turns your main fan on
Did you jumper the A/c pressure switch plug?
Switch goes open when the A/c on so if plug is just hanging in there ECM thinks A/c is running and turns fan on as soon as key turned on
St. Jude Donor '10
Its there,the problem happens when the ALDL cable is off and away...i just put the Key on and same thing...fan is on !
St. Jude Donor '10
There are 2 pressure switches on the line. The one involved in turning the fan on is the one near cylinder 6 closest to the firewall on the passenger side.
Guys, i just found a video of the first start and i noticed that the fan was running !
So , i can discard the chip or the aldl tryout. Its something else,im sure one of the upgrades or maybe i did use a clip to bridge the compressor connector and i did the same with another two connectors near the firewall,that were AC related,is one of those the A/c pressure switch plug ???
St. Jude Donor '10
I just measured the switch and yes it is shorted when "Off" as Rodj says. The connector is a little black round one with 2 sockets. It is opposite cylinder 6 on the wheel side of the engine bay (not at firewall)
Hi Lemme,here i have the long tube where the connectors go attached,i will get this connected tomorrow and see if the fan stops,we'll see, i really hope im not in limp mode :!!!
