What sensor is this?
ordered the one from oreilleys and it didn't fit. The diameter of the thread was too small to fit into that hole in the head. Thiis is so frustrating.
edit: Also, I have another similar hole on the other passenger head. Is this also for a temp sensor? I have a green wire on that side that just has a slip connector on it, rather than the pigtail. Is this the wire that attaches to this sensor?
The sensor probley is correct,its your heads that are the problem.You said that the heads are upgraded heads right?If so what heads are they?Any part numbers stamped on the head you can read?Maybe the heads are slightly different from your stock heads?If you have your stock heads see if the hole size is the same.If hole is too big might have to install some type of threaded insert so the sensor can be installed in that location.Keep us posted
The other head holds the temp gauge sender, and yes, it's a single green wire with a blade receptacle.
well...this is weird. I posted earlier this morning, but my post disappeared.
Anyways, I left the sensors at the shop, but looked at my old heads today (which I have here) and it looks like the hole is in deed smaller on the originals. Thanks for the tip on that guys. I just assumed they would be the same. Once I find an adapter, I will post to let you know if it got put together. I can' tmake it back to the car til friday though, so it might be a minute. Thanks again for the help.
Josh...that is the correct part number, as I just got that number from my dealer on Friday. I was also looking at the sensor for the other side of the head. Would you believe that the dealer wanted $67 for that sensor? Thats crazy stuff.
Everything looks great guys. Thanks again for the tip. Hopefully the car will be done this weekend....just before the cold weather sets in.
Actually, you don't need it, so you can put a pipe plug in the hole if you want to. From the Factory, the ECM is going to drive (ground) the Main Fan Relay at 226 degrees and that signal is from the thermistor or Coolant Temp Sensor screwed into the intake manifold below the throttle body (unless the a/c is on at which point it will drive the Fan when the High Side hits 230 psi). Individuals do buy these "lower temperature" fan switches that can work independently of the ECM or be spliced into the ECM circuit - The Main Relay is at Pin C1 - and crank on the fan (non a/c) at a lower temp. Whatever you do, don't override a/c control or the fan might not come on until a hose ruptures and blows a hole in the hood.
