Can a optispark vacuum harness be made with parts from local autoparts store?
![](/forums/images/ranks/1k-2k.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
I need a vacuum harness to complete my conversion from a nonvented optispark to a vented opti. On ebay these vacuum harness for the vented optispark are going for $70+ so I decided to build my own optispark vacuum harness and save some money, can this be done with parts from my local autoparts store? And if so what parts will I need to purchase or i'm better off just paying the $70?
![](/forums/images/ranks/100-500.gif)
I happen to have the check valves and some of the hose from a vented Opti spark off of a 1995 Z28 Camaro, $20.00 shipped...sound better?
Let me know.
Ben Smith
Let me know.
Ben Smith
![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
![](/forums/images/ranks/3k-4k.gif)
you not only can make a vacumn harness...you can make a better harness...using better quality hose, and run it in a better, more protected route than the factory. good luck
as I best recall the small hose is a 1/8 inch vacumn hose that runs from the opti to a fitting in the air intake tube; this brings fresh air into the opti.
the vacumn part is the large hose that runs off the opti to the intake manifold; I used 5/16ths inch fuel line and ran it all the way to the intake manifold before necking it down to the small hose that actually connects to the intake manifold...the factory does just the oposite; it uses a short piece of 5/16ths hose and 1/8th hose for the remainder.
regardless, the small hose requires a check valve just before the intake manifold; I found one of these in the generic section of all the little odd and assorted clips, fittings, and other parts.
that left only a filter to put in the 5/16th hose; a very small generic metal gas filter with 5/16th inch barbs proved ideal.
to transistion from the 5/16 th hose to the 1/8 hose only required a generic plastic vacumn line adapter.
got everything at O'Reilly's / Kragen; believe the check valve is a generic Dorman product from the A.C. section; the small generic fuel filter I used was just hanging on the rack with the other filters
But doesn't that straight manifold vacuum have to be reduced. GM uses a filter / reducer which I believe the hole is reduced to a diameter smaller than a very very small sewing needle. In this way the ECM does not read a larger than normal manifold vacuum leak
I don't think "a diameter smaller than a very very small sewing needle " would be sufficient; there has to be sufficient flow to actually ventilate the Opti body; In any case the harness I fabbed up worked fine; the smallest i.d. was the i.d. of the plastic 1/8th inch hose barb (pretty small); there was no driveability or idle issues and the car passed California smog without a problem .
And yes that Petris piece is nice
![Big Grin](https://www.corvetteforum.com/forums/images/smilies/biggrin5.gif)
And yes that Petris piece is nice![Big Grin](https://www.corvetteforum.com/forums/images/smilies/biggrin5.gif)
Well that's quite a bit larger diameter than the pin hole in my GM filter / restrictor disc. However, I will remove that and see if I get good results like you have. I did briefly Hook Up full manifold vacuum to the Opti and received an almost immediate 22 pounds per square inch at the fresh air intake in front of the MAF
