how do i put in a Passenger window glass???
![](/forums/images/ranks/100-500.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
ive been searching around and i cant find any definitive answers. my passenger window, on my '86, shattered when the door was closed. ![Mad](https://www.corvetteforum.com/forums/images/smilies/mad5.gif)
i found a replacement window for a good price. took off the door panel and removed all the broken glass (it was everywhere) removed the bolts that held the old glass to the guide. pretty straight forward.
now...
when i went to put in the new glass, i could get it into the door. i tried to go thru the top of the door. but the window guide (closest to the side view mirror) doesn't have an entry point into the door. there is a metal plate that is blocking it from going into the door. i don't see how to remove it. it looks welded on. my question is...how to get the glass into the door?? i need some help with this one.
thanks everyone
now...
thanks everyone
![](/forums/images/ranks/5k-6k.gif)
![Yes Nod](https://www.corvetteforum.com/forums/images/smilies/yesnod.gif)
![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
![](/forums/images/ranks/7k-10k.gif)
There are two felt covered guides at the top of the door, one in the front and one in the back. They are mounted in slots. You need to loosen the bolt and let them drop to the bottom of the slot to open up the area where the glass goes in.
Check this out:
http://www.mamotorworks.com/corvette-3-30-8514.html
They call it an anti-rattle cushion about in the middle of the video.
Check this out:
Check this out:
Check this out:
They look like this:
![](http://i184.photobucket.com/albums/x214/engle1147/doorfelt.jpg)
ok here is what i have a problem with. how do i get the glass pass this?![](https://a4.sphotos.ak.fbcdn.net/hphotos-ak-snc7/314452_10150411737269592_735259591_8468840_1067213847_n.jpg)
![](https://a7.sphotos.ak.fbcdn.net/hphotos-ak-snc7/391087_10150411738594592_735259591_8468852_1064802073_n.jpg)
the other part of the door has open slots for the glass bolts to go into the door
![](https://a2.sphotos.ak.fbcdn.net/hphotos-ak-snc7/374784_10150411739069592_735259591_8468857_704787902_n.jpg)
but not the stopper. how do i get past this? i cant see anything to unbolt. it looks like it is welded
![](https://a7.sphotos.ak.fbcdn.net/hphotos-ak-ash4/392962_10150411740724592_735259591_8468865_198175492_n.jpg)
![](https://a6.sphotos.ak.fbcdn.net/hphotos-ak-ash4/381785_10150411742004592_735259591_8468869_152494583_n.jpg)
1 Post
Cruise-In X Veteran
St. Jude Donor '09
Now that I see the picture, I have an answer. If you closely at that stopper you will see a top of a bolt. That bolt screws into a washer/nut on the outside of the glass. Channel Locks are your friend here. Remove it, drop the glass in and reinstall it.
I just did this last week to replace the motor, my stopper was loose and caused the window to jam so the motor replacement was unnecessary.
thanks for your help. one more issue..once the glass is in, how do you put the stopper back on? i don't have access to that area of the glass once its in the door
The big aluminum panel still needs to come out to effectively access reload the pivot into the actuator track. Perhaps you do/did need to unbolt the pivot before you drop it "in". Man, if I am remembering correctly there are larger gaps at each end of the window slot (just under the jamb's upper edges of the weather strippng) I'm pretty sure I stood the window vertically, dropped the front edge in past the bolt on pivot then rotated the window back horizontally as I slid the whole thing "foward" to where the other studs dropped through the pre cut holes you took the pics of.
I had to repair the driver's window regulator last year on my 87.
I removed the glass & reinstalled it after making repairs.
I recall removing & reinstalling the the glass window vertical.
You have to remove the large aluminum sheet metal framework 1st.
Lots of screws & bolts I remember too.
Make the glass adjustments carefully.
A large sheet of newspaper unfolded & placed on top edge of the glass then closing the door is a great way to test for proper door closing.
Window fully rolled up.
Newspaper should not pull out easily or not at all when adjustments are correct anywhere the glass makes contact with the weatherstripping.
Done correct You will have no water leaks with a garden hose test & no highway wind noise with window full rolled up.
Window glass can be adjusted to the front & rear of the car, in & out, & full upward glass stops too on the front & rear leading edge.
Work slowly & pay attention to the old "WITNESS MARKS from the glass adjustment bolts installed by the Corvette Factory Workers in Bowling Green, KY.
Save some time & mistakes that way for You.
BR
BR
Suckin' gas, haulin' ass.
When I removed my 89 passenger glass, I couldn't get the bolt loose for that stopper. I ended up drilling out that section shown to get the stopper past. If you look on the drivers' side, it's already cut out.
