LTCC Install
![](/forums/images/ranks/100-500.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Got the Bailey Engineering LTCC Conversion installed on my 1996 LT1.
The hardest part of the install has been figuring out how I wanted to install the coils, and getting cylinder 6 & 8 plug wires installed. (EGR tube in the way)
The install was pretty much straight forward, but there did appear to be one wire left out of the actual verbiage in the instructions, but it was listed in the wire table.
I chose to NOT drill holes into my Valve Covers to mount the coils, and instead used the stud locations for the plastic engine covers.
For the OEM ICM and Coil connections, I chose to not cut off the OEM connectors, and instead tapped into those wires just in case I might want to revert back to the OEM Optispark ignition. (Very doubtful)
Virtually every component used for the coil mounting came from McMaster Carr. The coil plates are 1/4" x 4" x 12" Aluminum plates, and I had a Machinist round the ends of the plates. The coils are separated with 1-1/2" steel spacers. If you do this conversion, DO NOT cut both sides the same. The stud locations are not the same from side to side, and the thread is M6x1.0.
The car started right up the very first time, and the only thing I notice different is when you rev the engine in park, it will give a pop from the exhaust which it didn't do on the OPTI. The car runs great so far. Don't know if there was a power change, no access to a dyno.
Tune ups are now going to be easier, and not require removal of the water pump and balancer, and the wires are much easier to install now.
I'll try to get some more pictures uploaded later. Still trying to deal with my Mom passing last month. The picture now is just with the coils in for a hood fit check.
Nice, very clean install. I left the connectors on my 94 intact as well just in case I wanted to go back someday. I have fabbed aluminum rocker covers which made mounting coils a little easier.
Computer doesn't need to be flashed. On my 94 I did have to pickup the tach signal from the PCM harness to get the gauges to work and the ASR light to go out.
![](/forums/images/ranks/2k-3k.gif)
Very nice install. I've been running the LTCC on my Impala SS for 5 years (60,000 mi) and have had no problems at all. I even bought a used module because I take the old girl on road trips and just didn't think Autozone or NAPA would be able to help if it failed.
Getting the high voltage out of the opti should make it last much longer.
I'm putting another LTCC on my LT4 Vette engine and won't look back. I didn't want to drill holes in valve covers either. I used the fuel rail mounting bolts (longer) to hold mine.
![](http://i118.photobucket.com/albums/o100/billburgette/IMG_2214.jpg)
I like the fact that you have plenty of clearance to get to the plugs on 6 & 8 in the picture. I have shorty headers on mine, and the dang EGR tube is in the way, so I haven't been able to put the new wires on those two yet, and still have the old wires feeding them.
![](/forums/images/ranks/11k.gif)
The brains behind DelTeq are like genius level... I read he got an offer he couldn't refuse from the defense industry.
I have LTCC... even rewrote the manual...
Donno which version you got.
Great product. I have had it for over 10 years and no issues.
![Smile](https://www.corvetteforum.com/forums/images/smilies/smile5.gif)
I have the version that you wrote that has V1.9d on the cover, and what Bob emailed and included in the box was also V1.9d, but they were completely different. The version you wrote was for the version that had the 8 separate coil connectors. The version I got that he's shipping now only has two coil connectors, and you have to have the factory coil harness too.
Pro Mechanic
There is a "Brain" in a nice metal box that taps into the OPTI signal at the test plug on the right side of the intake, and coil/ICM wiring, but I can't answer that question.
Pro Mechanic
Got it. Thanks! It has it's own "brain" that deciphers which cylinders are where using the low res signal, then fires each coil accordingly, it looks like. Thanks for the link.
yes, the brain interprets timing, the coils are intelligent and set dwell themselves based upon signals.
And yes, the harness has been updated to use the LS2 style coil harness assembly. Much cleaner, and the leads are longer on the harness.
I have had mine so long, I have had both harnesses! The original was destroyed several years ago when the serp belt blew up, taking the harness and ripping it to shreds.
