shifter knob removal
![](/forums/images/ranks/7k-10k.gif)
Location: Almost all Skyline Cruises Vettes at Waterside 1-5
1 Post
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
![](https://www.corvetteforum.com/forums/images/ranks/cf15.jpg)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
How do you remove the shift **** from an automatic????????? without tearing it up.
With some flat bladed screw drivers, pry up and remove the plastic shift button.
Look down inside and you will see an O ring that holds on the ****
Lots of parts places sell cheap O ring removal/install pliers to get this part out.
Once the O ring is out, the **** will slide up and off.
I have also done it with a screw driver to pry apart the tabs on the O ring!
Pliers are easier and potentially less damaging
Jack
[Modified by jackdaroofer, 8:13 PM 10/5/2002]
![](/forums/images/ranks/3k-4k.gif)
![](https://www.corvetteforum.com/forums/images/ranks/cf20.jpg)
Do it just like "jack" said to do it. However, my 89 has a metal snap ring that holds the shifter **** to the shifter shaft. This ring is a bit pesky to remove. After removal of the ring, the know just slips right off!
1 Post
Cruise-In I Veteran
Cruise-In V Veteran
:cheers:
Elite Torch Red Member
It's a snap ring :D
1 Post
Cruise-In I Veteran
Cruise-In V Veteran
It's a snap ring :D
When I become President, you will be my Secretary of State :jester
:seeya
![](/forums/images/ranks/2k-3k.gif)
Thanks fellas :cheers: Pulling the interior tommorrow for dynamat install and that was the only thing that I had no clue as to remove. Fortunately for me I have snap ring pliers :D
