LS Swap Accessory Brackets
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Bills Hot Rod Co. 200 Series LS Short Accessory Drive Kit, Raw (speedwaymotors.com)
Just wondering if anyone has had any experience with using these for their LS Swap? I am debating on getting these. Looks like they might do the trick for my 6.0/4L80e swap and the kit is a bit more affordable than the ICT billet kit.
![](/forums/images/ranks/3k-4k.gif)
That kit seems expensive. If you want to get a pre done kit I would look for one that doesn't include the water pump, alternator or AC compressor. Then either source those parts through Rock auto or a salvage yard.
That and in the pic in that link they are sending you an LS1 water pump. Get an LS3 pump so the upper hose is on the correct side for your radiator. This cleans up the engine compartment a lot.
I would look at Dirty Dingo. There prices on accessory kits are a better.
