Newb question
![](/forums/images/ranks/100-500.gif)
![](https://www.corvetteforum.com/forums/images/ranks/veteran_army.png)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
I've never taken an engine out of a Corvette. Mine is a 94 6 speed. I was at the dragstrip and accidentally went from 2nd back into 1st. On the way home, the fuel mileage dropped to 20 and it began to run really rough. A code said I had voltage issues, which I'm guessing means I over-revved my alternator. It would also explain the rubber squealing sounds I heard if the bearing was starting to go. That would be easy. But... I also started hearing a rod knock probably in the #7 cylinder. The car has been autocrossed a lot before I got it. It has been to Sebring as well, so it makes sense to tear it down and really check it out.
So, my question is, what's the best way to take the engine out? A qwik jack came with the car, so that helps a lot. Is it best to just take off the intake, then the headers and heads? Does that free up the space I need to get it out, and to more easily clear the hood? Or am I a victim of wishful thinking?
My technique.
get car in air on 4 Jack stands.
remove exhaust
remove c-beam driveshaft
remove trans
remove bellhousing and clutch
Moveup top and start disconnecting everything else
LT1 I usually get the intake off.
Remove front wheel, use engine hoist and come in from the side. I prefer the passenger side.
Engine out and on stand
remove exhaust
remove trans
The following 4 users liked this post by ChumpVette:
I pulled a L98 C4 engine back in the mid 90’s. I do remember the exhaust manifolds came off first followed by the y pipe for install convenience. Torque converter was unbolted then the bell housing bolts. Motor mounts were unbolted, radiator and fan removed. Upper plenum and runners removed (won’t have to in your situation)…..then a cherry picker lifted her out. Of coarse the AC, PS and what not were also unhooked. We didn’t remove the clamshell. Takes patience. Not sure if there is an adapter plate for the LT intake.
Well, this is why you ask questions first. I was thinking I could remove it with the trans in place. When I think about it, I think I understand why it needs to come out.
Would you explain why a wheel needs to come off? And why you prefer the passenger side?
Oh, joy.... Well, I think I have one if those angle adjusters. I just hope it didn't add too much height. If it does, I could just change which chain links I put the bolt through.
How hard is it to remove the clamshell, if I have another person with me? I'm thinking maybe I could remove it, lift the engine, and put it back on. If this is a ridiculously bad idea, remember that I have zero experience with removing a c4 hood. Just thinking it could save a potential problem with damage to the clamshell or some other part of the car, trying to be so careful with the removal.
iceman2003 (05-28-2024)
My open space is on the passenger side. Also less critical stuff to work around. ECM, brake booster, brake master, wiper motor. Wheel comes off to allow cherry picker in closer.
Why suffer trying to get the hood lined back up the way it was. There is no need to remove it
I'm not sure I'll do it, just checking to see what might be involved that I haven't thought of, so I can decide whether or not to do it.
No need to remove the hood, the C4 clamshell hood allows one of the best access to the engine of any car... Just as suggested above pull it from the passenger side. The hood is not a traditional one on a typical car that needs to come off. The angle is not that bad on the hoist to lift it out... I would assume 90 plus percent do not remove the hood, but to each his own, good luck with whatever you decide... Cheers
![](/forums/images/ranks/3k-4k.gif)
Or are you saying leave motor and trans as 1 and pull both at same time, that is a very off balance load and I would think the shifter tower would take a Beating.
At the dealership we always pulled transmission and Bellhousing Stripped away anything in the way on the motor or Body and pulled out motorout Passenger side.
![](/forums/images/ranks/1k-2k.gif)
On that score when doing the more picky customers I had on a few occasions took a strip of bed sheet and a split pipe cover and did the hood edges
Thanks to all of you for coming in on it.
when you say in place are you saying unbolt the transmission and support and leave it in (which I never have done or would recommend) mostly because space is limited in the front with cross member.
Why do you want to remove the engine out? I'd make the right diagnostic first. If you suspect a connecting rod, take off an oil pan and check the bearings. Or, at least flush the oil and see if there is bearings in it (big metal particles). Measure compression in the cylinders. Put some gas to the cylinders and see if it remains there after 15 minutes. Use an endoscope to check the cylinder walls and valves. Tons of methods.
Even with bad bearings, you can replace them with having engine in the bay. You can even replace heads and pistons while having the engine in the bay. The only limitation is that you can't take off the crankshaft while the transmission is connected, and it might be hard (but possible) to measure crankshaft journals. But you'd notice a bad journal, and would feel it with a new (a sibling) bearing and torqued cap - the crankshaft will rotate stiffly.
