91 L98 Engine Block Surfaces
![](/forums/images/ranks/1k-2k.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Hi everyone, I am ready to install the heads on my 91 L98 and I need to clean my engine block surfaces. I have the gasket materials off but trying to clean the head gasket paint marks/imprints and get to a clean shiny surface. Any suggestions on what to use without scarring/gouging the engine block? I saw a couple of threads that says to use scotch brite. Does that work without scarring up the surfaces? Thanks.
![](/forums/images/ranks/2k-3k.gif)
![](https://www.corvetteforum.com/forums/images/ranks/veteran_navy.png)
Scotch bright is controversial. According to some sources scotchbright releases an oxide particle (IIRC) that is small enough to get between bearings and the surfaces they are trying to protect. According to others it is not. It is also said that shiny is not the goal, clean and smooth is the goal. I am sorry I do not have the answer for you but please take time to dig deeper into cleaning a blocks surface for heads. There are as many opinions as there are questions about cleaning the blocks surface.
hgoodwiniii (06-27-2024)
Scotch bright is controversial. According to some sources scotchbright releases an oxide particle that is small enough to get between bearings and the surfaces they are trying to protect. It is also said that shiny is not the goal, clean and smooth is the goal. I am sorry I do not have the answer for you but please take time to dig deeper into cleaning a blocks surface for heads.
Yea, I probably should have said smooth and clean; Dont care about shiny.
That's good feedback sheriffjim. Keep us posted. I'm going to keep looking and see what other option(s) may be viable, as well. Thanks.
sheriffjim (06-28-2024)
![](/forums/images/ranks/100-500.gif)
I’ve used lacquer thinner & a rag, it’s my go to when simple green doesn’t work. However I have used regular mineral spirits to wash down cylinders because it doesn’t evaporate as quickly as lacquer thinner.
