How much power and boost - stock LS1
how many pounds of boost
to run thanks any info is helpful lol exspecialy from peaple that have gurnaided there engines thanks
First of all, use punctuation and separate your thoughts.
Second of all, boost is a measure of restriction not a measure of power. There is no set boost limit but there is a somewhat advisable maximum horsepower the factory motor can consistently handle. If you use your rev limiter as a speedo it won't take much boost to destroy that stock motor or any motor for that matter.
Third the last reply was 12 years ago lol.
Turpid porpoise (03-05-2020)
The following 2 users liked this post by evileight:
aaronc7 (03-05-2020),
And since my last reply, I’m now sitting at 14-15 lbs and 647 rwhp.
Still all in the tune, stock heads, Ecs cam, meth for safety.
120k on the car, approaching 100k since I originally put the charger on.
Tusc (04-14-2020)
On my 1999, I'm at 673 rwhp on stock bottom ls1. Adding a 8 rib system with same pulleys and a second nozzle of methonal at the end of the month, but need to fix issues now I believe with spark plugs or vacuum leak. 70k miles now (17k with v-3 supercharger and head/cam etc)
Elic (02-25-2021)
Hi judd herei have the 02 ls 1 c 5 wondering how many pounds of boost i can run i beat the ***** out of this poor girl lol as in i dirtroad her everyday an use the rev limiter for a speed0 i have howards CAM 243heads 92mm intake 80mmbbk throttlebody 25percent underdrive pully compcams rods howards behive springs mclan clutch im looking to push past unsafe to find the weak links got the turbo an intercooler an the parts also woundering a little info on what wastegate
how good's your tuner? if he sucks, it could very well die driving like that under vacuum.
i made 540h/550t-ish on 10-11psi for about 8yrs & 30k mi with a stock 2000 LS1 long block.
now i'm up to about 13psi on a stock bottom making almost 700h/680t.
500 rwhp running up to 11psi. Only got it finished last year. She runs strong and is holding together but I do not kill all the time. You will need good tires because mine are pretty useless as I spin like crazy....but it's so much fun...
