When BlownBlueZ06 gets bored......nitrous
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Many of you know what happens when I get bored......I find something to do. I always wanted to know what a little shot of nitrous would do for me. I've thought about it for a long time and finally decided to jump. I contacted Nitrous Outlet and picked out all of the parts to make my system look good and be reasonably reliable. I also wanted it to be serviceable, so I bought weatherpack plugs and pins to allow me to remove or isolate sections of the system. I didn't want a permanently mounted switch plate, so I made one that allows me to plug it in when I want to go out and play.
Having the nitrous allows me a few things. In roll racing, I no longer need the high RPM in the gear to prevent from entering a gear with lower torque. Entering a gear at 4500RPM provides the power, but forces an almost immediate shift allowing my opponent to gain momentum. I bought an FJO window switch that will allow me to set it where I get the hit and have a reverse progressive curve as I gain RPM and boost comes in.
![](http://www.bradbury.org/bret/nitrous-kit.jpg)
Here's the main part of the kit.
![](http://www.bradbury.org/bret/Controller-nitrous.jpg)
the FJO controller with USB interface
![](http://www.bradbury.org/bret/nitrous-plate.jpg)
The plate
![](http://www.bradbury.org/bret/solenoids-mounted.jpg)
solenoids mounted on the intake
![](http://www.bradbury.org/bret/harness-pinning.jpg)
pinning the weatherpack harness
![](http://www.bradbury.org/bret/harness-custom1.jpg)
under hood harness completed
![](http://www.bradbury.org/bret/solenoid-wiring1.jpg)
all connections soldered and covered in heatshrink
![](http://www.bradbury.org/bret/solenoid-wiring.jpg)
solenoid connections complete
![](http://www.bradbury.org/bret/TPS-and-coil-tap.jpg)
falling TPS and coil connections for the FJO controller. Dark blue is the falling TPS voltage and green with a white stripe is the coil connection I chose. When programming the FJO, you must use signal X2 since the spark only fires every other revolution. If then PCM had a "wasted spark" function, firing every revolution, then no math function would be needed for setting up the coil parameters.
![](http://www.bradbury.org/bret/switchplate2.jpg)
little custom switch plate.
![](http://www.bradbury.org/bret/switchplate.jpg)
![](http://www.bradbury.org/bret/switch-plate-back.jpg)
![](http://www.bradbury.org/bret/PSbracketr.jpg)
cut and welded the power steering bracket to accommodate the space that the plate takes up.
The plate
![](http://www.bradbury.org/bret/bracket-custom10.jpg)
Here are some pics of the brackets I made to mount the bottle to the bowl shaped area in the back well. I welded 1/2" studs to the brackets and use a large plate, washer and nut on the bottom side to hold the brackets in.
![](http://www.bradbury.org/bret/bracket-custom5.jpg)
![](http://www.bradbury.org/bret/bracket-custom6.jpg)
![](http://www.bradbury.org/bret/bracket-custom7.jpg)
![](http://www.bradbury.org/bret/bracket-custom4.jpg)
![](http://www.bradbury.org/bret/bracket-custom9.jpg)
![](http://www.bradbury.org/bret/custom-brackets-final.jpg)
![](http://www.bradbury.org/bret/bottle-bracket-custom.jpg)
![](http://www.bradbury.org/bret/heater-mounted.jpg)
With the carpet in.
I'm still waiting on the straps from Nitrous Outlet. They've been out of them for some time now.
![](http://www.bradbury.org/bret/bottle-covered.jpg)
Here's the bottle mounted with the cover on. It was a tight fit to get it under the cover.
![](/forums/images/ranks/11k.gif)
Received 1,768 Likes
![](https://www.corvetteforum.com/forums/images/ranks/cf15.jpg)
Bret, man only you and time on your hands and nothing to do.
Crap that should feel nice when it hits how much of a shot are you doing man...
Dont say 50 or 75![LOL](https://www.corvetteforum.com/forums/images/smilies/lol.gif)
![](/forums/images/ranks/5k-6k.gif)
I would figure you would spin in any gear when shifting before, how are you not spinning when this kicks in after a shift? Don't forget the big NOS stickers!
![Hide](https://www.corvetteforum.com/forums/images/smilies/hide.gif)
![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
Reading this makes me want to book a flight down just for a quick ride in this beast. I dont think theres gonna be much out there that will hang with you, you will get such a big jump on ppl. Nice job bro
![Wink](https://www.corvetteforum.com/forums/images/smilies/wink5.gif)
![](http://www.bradbury.org/bret/nitrous-engine.jpg)
I haven't figured out what to do with my purge line yet. Soon as I do, I'll bend one out of stainless.
I'll be sure and get those stickers on ASAP!!
That is crazy. Hmmmm I have an old kit sitting in the basement....Has anyone ever drilled out a nitrous plate and put Meth nozzles in it? Was wondering if that could be set up in place of where the MAF is on most cars that go SD.
