Help: Why does my belt keep coming loose?
![](/forums/images/ranks/100-500.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Hi guys, I have an 02 coupe with a pro-charger p1sc1. I'm running a 3.85" blower pulley, I have an A&A 3rd gen bracket, billet innovators west crank pulley, and ECS fixed idler assembly. I bought the car last August, and it already had the mods done. In November the belt came loose and I noticed a drop in boost, so I tightened the belt and I maxed it out. It worked for a little while then went loose again. So, I bought a smaller belt and got it good and tight. This new belt might have about 200 miles on it. This past weekend I noticed a drop in boost again. Now the new belt is loose. I gotta admit I'm a novice with the forced induction stuff so I might be missing something simple. The pulley's are only 6-rib, and I thought maybe they should be 8-rib? I'm going to tighten the new belt more on Wednesday and see what happens. Any ideas as to why my belt might keep coming loose? Thanks in advance for any advice!
The belt I put on was a car quest belt. The rib side seemed ok on the old belt. I haven't looked at that side on the new belt. But I don't see any black dust from the belt anywhere. It will max out at 12 pounds of boost.
![](/forums/images/ranks/11k.gif)
Received 1,768 Likes
![](https://www.corvetteforum.com/forums/images/ranks/cf15.jpg)
![Crazy2](https://www.corvetteforum.com/forums/images/smilies/crazy2.gif)
![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
I'll check that out when I get a chance to pull it off. What belts do you guys suggest I get? Thanks!
![](/forums/images/ranks/4k-5k.gif)
Mark your tensioner pulley and see if that's moving on you. Maybe you need a lock washer. Crank down on those two bolts. Top and bottom. You do have the adjustable pulley correct from A&A?????? I don't think your belt could streach that much
I took it that he had all the correct parts here to run the set up..I am also taking it that all the pulleys are lined up correct are with a loose belt also he would be cutting the belts and coming off the pulleys. Robert
http://www.aacorvette.com/supercharg...roducts_id=163
I checked the tensioner bolt and the top bolt. Both were super tight.
Gates belt is what you want to run. If the adjustment idler on the bracket hasn't slipped (moved in the bolt hole groove), your belt might be streatching. The belt needs to be tight to begin with too, mine is as tight as I can get it. I just leave a little swing left on the spring loaded idler.
![I Agree!](https://www.corvetteforum.com/forums/images/smilies/iagree.gif)
Former Vendor
Sounds like the belt is too long still. You should not be able to just slip the belt on and then tension. The belt should fight hard to get on before tensioning.
