C5 Z06 seat dismantle
![](/forums/images/ranks/4k-5k.gif)
![](https://www.corvetteforum.com/forums/images/ranks/veteran_navy.png)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Hi from C3 land. Im putting C5 Z06 seats in my C3 with VERY low customized slider tracks -inspired by CARPEDM. I have a couple of questions about the C5 seats I hope you guys can help give me some direction with.
Is it possible to remove the electronics & motors on a C5 Z06 seat without having to remove the lower foam?
Can the lower seat cushion skins and foam be removed without having to remove the top section?
Can you remove the cushions off the frames without having to pull off the skins?
Appreciate any replies
![](http://forums.corvetteforum.com/attachment.php?attachmentid=47622106&d=1207354304)
Brent.....
Brent.....
Received 9,045 Likes
![](https://www.corvetteforum.com/forums/images/ranks/cf20.jpg)
You will have to remove the lower skins and foam to get the tracks off the seat. Although the Z06 seats are not sport seats the only major difference is in the seat back foam and skins. The Z seat only has 1 foam piece and 1 skin for the seat back. Here are some instructions on how to take apart a Sport Seat:http://www.vetteessentials.com/instr...er_change.html .
I put sport seat skins on my Z seats two years ago and followed these instructions. You can remove the seat bottom skin and cushion without removing the seat back skin and cushion.
You have to pull the skin to get the foam off.
Bill
Bill
![](/forums/images/ranks/3k-4k.gif)
Actually, to get the tracks off, you do not need to remove the skins. You will have to reach up inside the seat with a 13mm ratcheting box end wrench (this is the only tool that will work). There is a nut on each corner that threads down on a stud or bolt (depending on the year). Feel for it first, and then fish the ratcheting box end in there. I have BIG hands and I can squeeze up under with no problem.
The following 2 users liked this post by JohnTheStigGalt:
Dbcrusader36 (05-29-2020),
Moto One (06-01-2020)
![](/forums/images/ranks/2k-3k.gif)
![I Agree!](https://www.corvetteforum.com/forums/images/smilies/iagree.gif)
![](/forums/images/ranks/1k-2k.gif)
C5 COTM Coordinator
![](https://www.corvetteforum.com/forums/images/ranks/cf10.jpg)
I decided to bring this old thread back since i'm also in the process of switching out my z06 black seats for mod red z06 seats. So in order to remove the seat track from the seat you wont need to remove the seat bottom to get to the bolts? What about when it comes to re-fastening the new seat, can this still be done without removing the bottom?
![](/forums/images/ranks/5k-6k.gif)
![](https://www.corvetteforum.com/forums/images/ranks/cf15.jpg)
As mentioned in the previous posts, you will not have to remove anything but the four fasteners per seat.
You won't be able to see the fasteners, but your wrench will be able to tighten/loosen them. (one on each corner)
![](/forums/images/ranks/100-500.gif)
Hey guys I have a set of these seats I’m about to put in my c3 and was wondering what you used for the hardware when mounting the c3 tracks to the bottom of the c5 seats, thanks a bunch!
hey when you put them in your 71 was there clearance enough for them to slide on the c3 seat tracks or did you end up using washers for spacers?
