Best Cleaner for Inside of Exhaust tips?
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
To get the bad carbon off I used 00 steel wool and some windex. They once cleaned up I used some SemiChrome(this stuff is the best) and then wiped it off, they look like new and the semi puts a nice coat on it so you can just wipe the tips off after they are good and clean.
![](/forums/images/ranks/1k-2k.gif)
If you can find this stuff and you will never buy anything else, mine were solid black i sprayed a few sprays on it and the black started just running off.
a few sprays and high pressure hose and they look almost new.
I just took the pictures and I have not cleaned them in a while so they are not perfect but you can get the idea how good it works.
![](http://jeffsfireworks.com/cleaner.jpg)
![](http://jeffsfireworks.com/cleaner2.jpg)
