Another myth laid to rest?
![](/forums/images/ranks/4k-5k.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Glad you were able to get the lift installed. I would have liked to help but working retail around the holidays doesn't leave much weekend time
. How much is the garage door company charging you if you don't mind me asking? You have ten foot ceilings correct?
![Frown](https://www.corvetteforum.com/forums/images/smilies/frown5.gif)
![](/forums/images/ranks/11k.gif)
![Cheers!](https://www.corvetteforum.com/forums/images/smilies/cheers2.gif)
![Yes Nod](https://www.corvetteforum.com/forums/images/smilies/yesnod.gif)
The ceiling is 10 feet. The garage door lift is not quite standard since they had to order all new parts except for the door panels themselves. They are also installing my new opener for me while they're at it. It's a Liftmaster 3800 side mount and lift unit with remote keypad, switch and light module. It'll run around $900 for the job. I've seen companies do it for less but they were simpler jobs with a foot or less of additional rise and no other changes. The current opener is going on my other single door which currently has no electric opener.
![](/forums/images/ranks/3k-4k.gif)
Location: Lower, Slower Delaware, formerly from Mobtown, MD (Baltimore)
Nice job,
you're a better man than me. I'd of had 10 people there before I moved a thing, you know, bad back and all.......
![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
![Big Grin](https://www.corvetteforum.com/forums/images/smilies/biggrin5.gif)
I tried to get the builder to reverse the door so it opens to the outside but they refused and it's stucco'ed in place now so I'm leaving as is for now.
![](https://www.corvetteforum.com/forums/images/ranks/veteran_navy.png)
Received 20,041 Likes
'20-'21-'22-'23-'24
![](https://www.corvetteforum.com/forums/images/ranks/cf20.jpg)
![](https://www.corvetteforum.com/forums/images/ranks/cf-stjude20.jpg)
Nice job, Patches. Glad you got it all back together.
![](/forums/images/ranks/7k-10k.gif)
![](http://i234.photobucket.com/albums/ee49/vettesplus/98vette/Picture131.jpg)
2021 C6 of the Year Winner - Unmodified
![](https://www.corvetteforum.com/forums/images/ranks/cf15.jpg)
I put mine together without help the first time (not Bendpak). Did it much the same way, using a cherry picker. It can be done fairly easily.
That's what they call the "Man Door" in these parts. It's an access door to the back yard. It still opens fully but may be partially blocked by the time I move the lift to it's final resting spot and bolt it in (I have casters to move the lift).
I had a 4200 sq ft house built in Texas and they would do ANYTHING I wanted. I could have asked them to install a stripper pole in the kitchen and they would have asked what color? Lol
#33
Wounded Warrior Escort '11
![](https://www.corvetteforum.com/forums/images/ranks/cf10.jpg)
Cool and Thank You for the info. I've got a 9' ceiling in my garage and from the sounds of it, you had 9' 3" of needed space. I've got two Corvettes as well, a '99 and a '07. I've not measured both heights but will. I'm not as much interested in dual storage locations for both on the single lift, rather being able to get under one as needed. In this case, it appears its not an issue other than price. I like the idea of the shorter corner posts too.
#35
Location: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Great job, Ed!...been wondering where you've been? This should make you feel even better about your install...this was mine on a 6 degree January day; came pre-assembled...wew just rolled it in, but it had to clear the height of the garage door...it was tight!....and here is the opener I used...Liftmaster 'on wall' type...love it.
![](http://i104.photobucket.com/albums/m188/jgira12/spearsandracingstripesandgarageo-1.jpg)
![](http://i104.photobucket.com/albums/m188/jgira12/2008ColorsFloridaIforgedArescoLi-6.jpg)
![](http://i104.photobucket.com/albums/m188/jgira12/Copy2of2008ColorsFloridaIforgedAres.jpg)
#36
![cool](https://www.corvetteforum.com/forums/images/smilies/coolgleamA.gif)
Thanks for the pic of the opener.
#37
![](https://www.corvetteforum.com/forums/images/ranks/veteran_air_force.png)
Patches, (nice place, nice view, nice garage for the Vette(s), nice weather) sorry to hear you had to move to SoCal. Good luck with the smog, taxes, crime, taxes, drugs, traffic, gangs, taxes and taxes. (don't worry about riots, fires and mudslides...they got Sushi in the Mall)
JG, now in Idaho but a 1980 graduate of Lake Elsinore Union High!
#38
It took four of us and a case of beer to do mine. As food for thought since you are in earthquake territory. I drilled a hole in the I beam of each post, and ran 3/4 inch bolts through the holes. and let the lift settle on the bolts. There is no way in hell the lift can come down on my second vette. Food for thought. The last earthquake, I saw that the locking pins had moved a little and I was concerned.
