Infamous Belt squeal from heLL!!
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
I saw that so many of you had success with the Goodyear Gatorback belts that I got one (the main belt; stock # ends in 798) and put it on my 2001 5.7L. THE NOISE IS GONE; HOWEVER---- While replacing the belt, I noticed that as I would release and apply the belt tension on the main tensioner pulley (top of engine, passenger side), that the pulley would turn slightly sideways. (Tension off, the pulley would be straight; tension on, the pulley would go slightly sideways again.) Even though the new belt eliminated the squeak/squeal, I am convinced that the pulley was the main problem and I did not want a pulley out of line. I have just replaced the tensioner/pulley ($40 for the part). It took me less than 10 minutes to get the belt off, unscrew the two tensioner/pulley bolts and remove, and replace with the new tensioner. I've got a total of $60 in the belt and tensioner/pulley.
![](/forums/images/ranks/3k-4k.gif)
It might come back.
If it does, then you should check your two tensioners. Not the pulleys themselves, but the tensioners. When they wear, they start to twist, causing the pulley and the belt to not align correctly. When the belt runs slightly sideways on the pulley, it causes the squeal.
It is usually the AC tensioner.
![I Agree!](https://www.corvetteforum.com/forums/images/smilies/iagree.gif)
1st Gear
![](/forums/images/ranks/100-500.gif)
trust me bro it sounds stupid but you have no idea how annoying it is. Its constant when car is warmed up
harmonic balancer is the crank pulley btw
everyone's squeak noise is different some lucky ones only have to replace the belt or at worse the belt tensioner but mine didnt stop with those things
any one else please?
Thoroughly chapped
Location: If you're not angry, you're not paying attention
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
![](https://www.corvetteforum.com/forums/images/ranks/cf15.jpg)
![](https://www.corvetteforum.com/forums/images/ranks/StJude10.jpg)
Here was my solution:
My balancer did not wobble a bit...it had begun to delaminate, and had walked forward about an 1/8" of an inch. That in turn caused my a/c tensioner to angle to adjust to it's new position, which ate the bearing.
I ended up replacing the balancer with an ATI unit (overkill), the a/c tensioner completely with a Dayco unit (made in USA, instead of the GM unit that is made in Korea), all of the other pulleys, also Dayco, and the belts with Gates Racing Blue belts, the main drive tensioner with a fixed Katech unit. My a/c compressor was also barely leaking at the halves, but I wasn't taking any chances that the seeping oil was responsible for any of this, and changed it too.
No more squeaks or squeals....
![Cheers!](https://www.corvetteforum.com/forums/images/smilies/cheers2.gif)
1st Gear
What kind of powder cleanser? The squeal drives me nuts. The faster I go, the louder it squeals.
![](/forums/images/ranks/11k.gif)
![](https://www.corvetteforum.com/forums/images/ranks/veteran_army.png)
Received 3,814 Likes
St. Jude Donor '03-'04
![](https://www.corvetteforum.com/forums/images/ranks/cf20.jpg)
Welcome to the Corvette forum Susan. Do not put any cleanser on your belts... Find out which belt of the two ( the AC Belt or the drive belt ) ( both belts have a tensioner and an idler ) is squealing, and replace the belt and the tensioner and idler pullies for that belt system.
Bill aka ET
Bill aka ET
SusanD37083 (01-06-2019)
Received 1,233 Likes
St. Jude Donor '11
Welcome to the CF Susan...There is a very good chance that your harmonic balancer needs replacing....GM C5 balancers are famous for seperation and need replacing over time...especially if yours is the original from 2003...otherwise even if you change all the other things the problem will persist...![Cheers!](https://www.corvetteforum.com/forums/images/smilies/cheers2.gif)
St. Jude Donor '11
![*****](https://www.corvetteforum.com/forums/images/smilies/willy_nilly.gif)
St. Jude Donor '11
It wasn't that expensive...had my Vette since new in early 2004...a new balancer and a few other normal replacement parts...i wanted to start fresh after 14 years...time is the killing factor of the crap GM balancer that was purposely engineered to crap out after about 7 years of deterioration not mileage per say.....i paid more for my Z06 wheels...
...anyhoo...this Vette owes me nothing......i feel sorta guilty for being blessed with pleasure for the past 14 years...
![Smash](https://www.corvetteforum.com/forums/images/smilies/smash.gif)
![Hide](https://www.corvetteforum.com/forums/images/smilies/hide.gif)
![Flag](https://www.corvetteforum.com/forums/images/smilies/patriot.gif)
I have the same problem this year, replaced two belts, cleaned all the grooves in the pulleys, what stumps me is that if the air or outside temps are warm ( over 65* plus ), the noise is gone until it cools off again.
#33
i have the same dam problem
here is what a replaced so far
1. belts on the 3rd one now (including gatorback)
2. idler pulley
3. driver belt tensioner
4. Water pump (yep even that)
5. Crank Pulley
Replaced ac belt.
Drove without ac belt noise still there
Is there anything left???
Alternator pulley?
Someone please shoot me
Im seriously thinking about putting it up for sale.
![Bang Head](https://www.corvetteforum.com/forums/images/smilies/banghead.gif)
2. idler pulley
5. Crank Pulley
Replaced ac belt.
Alternator pulley?
#34
![](/forums/images/ranks/4k-5k.gif)
#35
DECON BLUE (08-30-2020)
#36
The C5 Harmonic balancer has two known problems, on is the de-lamination of the bond or the bolt becomes heat cycled and the balancer moves forward into the power steering rack. Many who have HPDE, raced or autocrossed their cars have experienced this problem. For the race cars and HPDE cars, the ATI, etc HB was an easy replacement for those who autocross in a stock class, you had to replace it with a GM one. The only recourse was to pin the balancer. In either case: separation or movement, the belts will sequel loudly and confuse what is the problem--usually a tensioner.
#37
My chirp was remedied when the idler for the AC belt was replaced. Also - just before going to Carlisle I read some notes from a seminar I attended last year. I recall reading that one (only one) of the idlers has a "depth adjust" and maybe fiddling with that would help.
#38
With the colder weather and the humidity in my area I’ve had belt squeak on start ups and it’ll stop once the car hits about 140 degrees had me stumped. To preface the vette started squeaking it about a week after I bought it put a new tensioner and serpentine belt in the squeaking stopped for about two weeks. Then started to come back. I looked into it possibly being
the harmonic balancer(checked no play or slippage)
tensioner(still tight)
belt(no cracks or wear)
ac belt and ac tensioner we’re both replaced right before car was bought checked both and they are still in great condition
one thing I’ve found is the power steering pump pulley on these cars are pretty terrible they can crack and due to them being pressed on they can become loose
to check this today I removed the belt checked for cracks(there was none) and there was no play)
after putting the belt back on there was no squeaking and the engine was cold so my problem has resolved itself I’ll update with any changes
I apologize for the long post.
