FRC transmission gear ratios
![](/forums/images/ranks/2k-3k.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
i don't think so, but if you go to the archive section of this site, you will find some pretty comprehensive info for the 1999 and your answer should be there:
http://www.gmheritagecenter.com/
![](/forums/images/ranks/7k-10k.gif)
![](/forums/images/ranks/5k-6k.gif)
![I Agree!](https://www.corvetteforum.com/forums/images/smilies/iagree.gif)
The Z06 has the M12 and the others are a MM6 code. There are some differences in the 5th and 6th gears also.
I found this information from the Corvette Action Center web site.
.....1999.......1999...............2001
.....FRC....Coupe/Convert......Z06
.....MM6........MM6...............M12
1st 2.66........2.66...............2.97
2nd 1.78........1.78...............2.07
3rd 1.30........1.30...............1.43
4th 1.00........1.00...............1.00
5th 0.74........0.74...............0.84
6th 0.50........0.50...............0.56
Rev 2.90........1.91...............3.28
I don't why the 99 coupe/convert has a different reverse ratio than the FRC but that is what it said. In 2001 it shows the standard to be the same as the 99 FRC.
You can check other years there too. They have a lot of good information.
