[Z06] 500hp to the wheels goal need help!!
#121
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Lmao You are looking at it the wrong way bro. A Ms4 camshaft with 225 runner heads would be made for all out top end power. You would have hardly any down low grunt or under the curve power. You would really need gears to help that setup out. Instead of strying to reach the almighty 500, set the car up right. Do some research on cylinder heads, and camshafts, valve events, look at some dyno sheets. With that setup up, you would have a dyno queen, and get b*tch slapped at the track. You pick.
#122
![](/forums/images/ranks/2k-3k.gif)
Location: Arlington Texas, originally from San Angelo, TX
Honestly I couldn't care less about dyno numbers, so I'm not going to post them. Given the title of this thread I'm sure you can piece things together though. The car was built for drag & Auto-X not to race grey haired little old laddies and mini van wielding soccer moms through the intersection.
346ci LS6
239/242 .649"/.609" @109 LSA
Cartek 3X 243s (milled to 62cc)
Yella-Terra 1.7 ULs/ TSP pushrods/ LS7 lifters/ PRC Extreme dual springs w/ titanium retainers/ Comp locks
Katech C5R timing chain w/damper/ Katech J-grade connecting rod bolts/ Katech oil pump/ Katech manual tensioner
Tony Mamo ported FAST 92mm w/LS2 TB (port matched to Cartek heads)
Kooks 1-7/8" LTs/ 3"x3" off-road X/ Borla Stingers
SLP underdrive balancer
Edelbrock water pump
Turn-1 power steering pump
Blackwing w/ Ice-Box enclosure (IATs inline with Vararam)/ Tigershark front fascia
Speed density tune by Joshua at Resurrection Motorsports (redline @ 7300rpm)
Ram Street-Dual twin disk/ aluminum flywheel
C6Z TR6060
C6Z diff
Black Dog billet rear coupler
Tick HV master
custom engine, trans & diff coolers
PFADT coilovers, sways, engine & diff mounts
2008-2011 18" CTS spares for front runners (to fit over C6Z brakes)
C5Z 17"x9.5" w/MT ET streets out back
18"/19" CCW SP16a for street/ standing mile use
346ci LS6
C6Z TR6060
C6Z diff
Tick HV master
#123
Honestly I couldn't care less about dyno numbers, so I'm not going to post them. Given the title of this thread I'm sure you can piece things together though. The car was built for drag and standing mile not to race little old laddies from stop light to stop light.
346ci LS6
239/242 .649"/.609" @109 camshaft
Cartek 3X cylinder heads
Yella-Terra ULs/ TSP pushrods/ LS7 lifters/ PRC Extreme dual springs w/ titanium retainers/ Comp locks
C6Z TR6060
C6Z diff
Tick HV master
346ci LS6
C6Z TR6060
C6Z diff
Tick HV master
pics?
Is the 109 with ICL or LSA?
#124
![](http://i16.photobucket.com/albums/b35/mattlenn/DSCN0624.jpg)
#125
![](/forums/images/ranks/7k-10k.gif)
![](https://www.corvetteforum.com/forums/images/ranks/veteran_navy.png)
Received 2,084 Likes
![](https://www.corvetteforum.com/forums/images/ranks/cf15.jpg)
346ci LS6
C6Z TR6060
C6Z diff
Tick HV master
346ci LS6
C6Z TR6060
C6Z diff
Tick HV master
#126
Yes sir, an Alky-Control system/ retune will be coming very soon. Joshua initially tuned the car last week, so all I have gotten to do is a bit of street thrashing thus far. I definitely plan on hitting Dallas Raceway once I get the meth installed. DA on tap!
#127
#128
![Cheers!](https://www.corvetteforum.com/forums/images/smilies/cheers2.gif)
#131
#133
To read again:
http://forums.corvetteforum.com/1578355630-post24.html
Christian
#134
Post # 24 is my most complete best suggestion and you might always comment in the specific thread if there is something missing or you don't understand.
To read again:
Christian
To read again:
Christian
![Smile](https://www.corvetteforum.com/forums/images/smilies/smile5.gif)
