Anyone here do the Euro taillight conversion?
![](/forums/images/ranks/5k-6k.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
![](/forums/images/ranks/7k-10k.gif)
Location: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
you must remove
the baffle panel located below the steering column and above the brake pedal. It is held in place by
two “push” type retainer snaps. Pull these two snaps out, exposing the upper portion of the brake
pedal and its brake light switch. The switch is one of two switches on the bracket. Locate the smaller
connector that has three wires; White, Blue and Orange.
CUT THE WHITE WIRE. This is
necessary for proper function.
Received 2,741 Likes
2018 C5 of Year Finalist
![](https://www.corvetteforum.com/forums/images/ranks/cf15.jpg)
Yep. Been there and back with this mod. Ran Euros between 2005 and 2010 and then switched to LED Halos.
Here is the wire you need to cut if you switch to Euros. It is also the wire you need to reconnect if you ever switch back to stock or LEDs.
Take my advice, cut it with enough wire near the bottom to make reconnecting it easier.![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
![](http://i499.photobucket.com/albums/rr357/Allen2112/Corvette%20Pics/WhiteBrakeWire.jpg)
