Is it worth to swap out an H-pipe with Ti's?
![](/forums/images/ranks/100-500.gif)
![](https://www.corvetteforum.com/forums/images/ranks/cf15.jpg)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Looking to buy a used Ti exhaust cat-back and would like to know is there any reason to include the OEM Z06 x/h-pipe? I very seldom see the OEM x/h-pipe included in a Ti exhaust for sale. Thanks
John C
John C
Last edited by Old'75'Owner; 11-19-2011 at 09:58 AM. Reason: rephrased the question.
![](/forums/images/ranks/7k-10k.gif)
Location: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
First off you don't want to trade out an H pipe for an H pipe, You want an X pipe, I installed an X pipe on my TI and it ran smoother and sounded better.
![](https://www.corvetteforum.com/forums/images/ranks/cf10.jpg)
That's an idea. I am lookingf for a little sweeter sound above my stock exhaust. The X pipe just may put me there without changing my catbacks. Thanks for the idea.
![](/forums/images/ranks/11k.gif)
No not at all, you have the same stock H-Pipe and there is no need -
As stated above get the TI's and an X-Pipe and it will be a world of a difference![Big Grin](https://www.corvetteforum.com/forums/images/smilies/biggrin5.gif)
Thanks,Matt
Thanks,Matt
1 Post
'X' and Hi flo cats are the way to go. Throw in a set of long Tubes and you are done!![Big Grin](https://www.corvetteforum.com/forums/images/smilies/biggrin5.gif)
Had Ti's, great improvement over stock.
Changed to Magnaflow for that deep big-block sound. Check sig for more info...
![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
![](https://www.corvetteforum.com/forums/images/ranks/veteran_navy.png)
Received 20,037 Likes
'20-'21-'22-'23-'24
![](https://www.corvetteforum.com/forums/images/ranks/cf20.jpg)
![](https://www.corvetteforum.com/forums/images/ranks/cf-stjude20.jpg)
Received 1,685 Likes
Don't mess with changing a H pipe for another H pipe.
Swapped my stock exhaust for a magnaflow and a bassani X pipe. Hated the drone and swapped the magnaflow for stock exhaust. No drone but when you hit the loud pedal it sounds great, The stock H pipe restricts flow the X pipe opens the way for the exhaust to leave. I then added a blackwing and am happy. The Vette is quiet when I want itd and roars when it needs to.
![](/forums/images/ranks/5k-6k.gif)
A "correct" x-pipe improves on the pulse balancing by completely merging the flow of the two halves of the exhaust system.
The stock crossover on our cars is a joke. It's 2 1/2" just like the main tubes, but each one of those tubes has just one small hole leading into that crossover. The holes are about 5/8". This is not uncommon in GM exhaust systems.
When I say "correct" x-pipe, I mean one that is really shaped like an X, not a "merge":
Good:
![](http://www.slickcar.com/products/15437.jpg)
Merge style:
![](http://www.jscspeed.com/images/catalog/category11605_thumb_full.jpg)
Oldtimer
THAT is exactly what I wanted to know! Thank you!!!![Woohoo](https://www.corvetteforum.com/forums/images/smilies/woohoo.gif)
Some of the Xpipes I've seen online look like the merge example, where I was unsure if the pipes even opened to each other. The 'good' one shows how they should (I assume) be siamesed.
So, Is a good X pipe a smart investment? What's the effect if that is the only thing one changes? I like the sound of my Z's stock system now.
An h-pipe is supposed to be a crossover in a dual system used to help "balance" the pulsing found in an exhaust system. They can also reduce interior drone at certain harmonic points. On the old 5.0 Mustangs for example, a 1 3/4" diameter crossover added to the stock h-pipe 21" back from the drivers side header flange took a good 80% of the resonance out when using 2 chamber Flowmasters.
Good:
Merge style:
Good:
Merge style:
![Cheers!](https://www.corvetteforum.com/forums/images/smilies/cheers2.gif)
![](/forums/images/ranks/3k-4k.gif)
For what it's worth,,,there was a post some time back that was posted by a race shop that did extensive testing on dyno and track that stated that the "merge type X was actually better than the cross over X's. Both are good,,and WORLDS better than the phony/useless stock H (as you stated only about a half inch hole in the side of the main tubes at the H). Just thought I'd pass this along,,not trying to start a ruckus. Either will be a major improvement!!![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
