New 8 ball shifter knob
New 8 ball shifter ****
Well ever since I installed the short throw shifter I had been wanting to get a new **** on there went with a golf ball for a while until I got this one made. Just wanted something a little different.
Old one
What it looks like now
Old one
Yea I just needed something temporary so I grabbed one of my old golf ***** and stuck it on there until I could figure out what I wanted. I think I might mill out a section and put a metal plate with the C5 logo where the 8 is when I get a chance.
Received 20,035 Likes
'20-'21-'22-'23-'24
Looks really good.
Received 1,685 Likes
I like it!
I dunno... the eight ball just doesn't have the aerodynamics that the golf ball has. You might find your shifts are a bit slower.
Well Im actually thinking that with the added weight it should smooth the shifts out and maybe speed it up by a few thousandths. I had gotten so used to the golf ball that this feels kinda awkwardly large though and I could knock off shifts pretty darn fast before. Maybe Ill log it to see where Im at.
The first thing I threw on after instaling my highly-shortened C6 Z06 shifter was this:
Then after a few weeks of driving, I went to this one (only as a wine-red version):
I may pop in a slightly smaller ball version, eventually. Choices, choices......
Oldtimer
Matt, you did a great job. It's easy to 'spoil yourself' once you start making these things! I find that my #1 is a nice shape and size, but maybe a bit light. #2, which is offset, was shortened last nite and is soaking in stain, had more beef and actually eased shifting. #3, also offset is soaking in black stain, no pix yet.
The Christmas tree ornaments would make a good mold, now I just need to figure out a good resin to use. Or at least find a place that you can get solid colors or ones without numbers on them as they would be much easier to find the center and drill.
And yes the more weight that seems to be at the top the easier it is to shift, I think I may actually shorten my short throw shifter just to get it to sit a little lower now.
Oldtimer
She used to do that over 40 years ago, so I don't know the exact material. I think it was a 2 part deal. She also had colorants so they would be ....uh...different colors. The ornaments were clear, and she would break the glass away after the resin cured. BEFORE it cured, she would insert the floral wire to make the arrangements. I googled shift ***** and found a guy who showed some of the stuff he did on Youtube. He was into scorpions and other bugs as inserts into the molds. If you are going to make more of these, you need a 'receiver' of some kind to hold the sphere securely, like some of the suggestions you got on the other thread. Maybe a stout funnel? How will you shorten your shifter??
It would probably be easier to just buy the pool ***** that are basically blank if I can find them.
Oldtimer
There has GOT to be the raw material you want out there....
WAIT!! Here we go:http://plasticballs.com/index.htm
