[Z06] Clutch fluid question...
If I were to change the fluid in the reservoir, can I add dot4 to the existing dot3...or should I stick with the type 3 unless I purge the entire system?....so the question is does type 3 and 4 mix?...any adverse affects? :confused:
Received 1,310 Likes
2022 C1 of the Year Finalist - Unmodified
2021 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
Re: Clutch fluid question... (BLT2SPD)
Read the bottles, but every DOT4 I have seen clearly states that it is compatible with DOT3. It just has higher boiling points.
Apparently, the stock GM "cluth fluid" has an additive to prevent squeeking. I have also read that it's that same additive that reacts with the rubber seals to turn it black.
Good luck,
Good luck,
BLT,
use the GM factory fluid...........do not use brake fluid.......
The hydraulic clutch fluid is now available in 32oz containers........... :yesnod: :cheers:
