I bought my first Corvette!
Old 10-05-2022, 06:16 PM
Sojourner
Sojourner's Avatar
Default I bought my first Corvette!
Hey y'all, it finally happened today! Just returned an hour ago with the new beast. 2004 C5Z Yellow with 20,000 miles. All stock except for Koni yellow shocks and a front sway bar. They guy I bought it from has owned the car since 2005 with 1800 miles!
It also came with the OEM wheels and center caps.
The following 14 users liked this post by Sojourner:
Beezr (10-06-2022), CorvetteMike2024 (10-06-2022), Dads2kconvertible (10-05-2022), Eurx (10-07-2022), JamesNC (10-05-2022), JCMDoug (10-06-2022), Kubs (10-06-2022), mstromquist (10-10-2022), MWWarlord (10-06-2022), Prop Joe (10-05-2022), rrwirsi (10-06-2022), sonicss33 (10-05-2022), TCFS (10-07-2022), walleyejack (10-06-2022) and 9 others liked this post. (Show less...)
Old 10-05-2022, 06:21 PM
sonicss33
sonicss33's Avatar
Very nice and welcome aboard.
Old 10-05-2022, 06:22 PM
Sojourner
Sojourner's Avatar
The guy I bought it from was pretty meticulous about taking care of the car, and always did maintenance based on time and not miles. It seems in really good shape. I do have a few questions, as I tend to worry about my cars in general...
1. The harmonic balancer is from the factory. It looks good with no wobble. I already drew some marks on the two bands of rubber and went and drove it hard and they were in the same place. So i expect I have plenty of time, he kept the car in the garage and it basically never saw rain or cold weather being in the south. Is there any data that shows that around this age they start to go regardless of how they were treated? Or is it all dependent on their environment, and luck?
2. There is a small oil leak of sorts. He let me know before I bought. The inspection said rear main seal, but he thought it could be oil pan. It doesnt really drip on the floor, just smells a bit here and there. Should I just ignore it? I plan to get under and investigate it soon, but obviously rear main seal im not doing until clutch.
3. Clutch is also stock. Pulls hard. Any concerns with age on this?
4. Last, original plugs and wires. Should I replace sooner than later, or inspect and if they look ok just keep running them for a while?
Ive never bought a car this age with this few miles...
Old 10-05-2022, 06:43 PM
I’m Z one
I’m Z one's Avatar
2022 Corvette of the Year Finalist -- Modified
2021 C5 of the Year Winner - Modified
Congratulations on your purchase. I have an ‘04 Z as well (9,200 miles) with original HB, Plugs, Wires etc… I haven’t and wouldn’t change them if I was in your shoes. I don’t have any oil leaks and as a suggestion tighten your oil pan to the recommended torque specs and pattern. Once completed, spray it down with Brake Kleen and check it periodically after driving it. That will tell you if it’s the OP/gasket.
Lastly, what’s the last 6 digits of your VIN? Did you compare it to the suspect VINs for the gas tank(s) cross over tube issue?
c5arlen (10-09-2022)
Old 10-05-2022, 06:53 PM
Sojourner
Sojourner's Avatar
Mine ends in 45122525, so it looks like it does fall into the cross over tube numbers....I don't see any receipt in his records that it was fixed. What should I do?
Old 10-05-2022, 07:00 PM
I’m Z one
I’m Z one's Avatar
I personally wouldn’t do anything UNLESS you smell gasoline in your garage (assuming that’s where you park it). As a test, I’d fill it up as much as you can, do some spirited driving and park it (in your garage). If you still don’t smell gas fumes I wouldn’t worry about it. If you EVER smell gas fumes get it fixed ASAP.
just my $0.02
Old 10-05-2022, 07:06 PM
Sojourner
Sojourner's Avatar
just my $0.02
Can it potentially start a fire?
Old 10-05-2022, 07:10 PM
I’m Z one
I’m Z one's Avatar
Fire? No. Explosion YES!
Old 10-05-2022, 07:41 PM
vette4fl
vette4fl's Avatar
Received 2,399 Likes on 1,391 Posts
Talking about gas leak or oil leak? I thought I read very slow oil leak.
Old 10-05-2022, 08:40 PM
Sojourner
Sojourner's Avatar
Well now I'm a nervous wreck...
Old 10-05-2022, 08:52 PM
I’m Z one
I’m Z one's Avatar
No worries as long as you have an “agreed value” with your Collector Car insurance Company and an up to payment/policy with your homeowners insurance. It could be a blessing in disguise.
Not trying to be a d**k but you should be proactive rather than reactive.
Old 10-05-2022, 09:13 PM
Sojourner
Sojourner's Avatar
I just brought the car home. It's been in this guys garage for 17 years. I'll call the dealer and see if it had the recall done. Then I can test for gas smell.
Old 10-05-2022, 11:34 PM
Mike98SilVert
Mike98SilVert's Avatar
Received 3,159 Likes on 2,089 Posts
Congrats on your first Corvette, great find.
What a great example, I had a Millenium Yellow 2002 Z06.
Good information:
2001 - 2004 Corvette Z06 Tech Center - Corvette Action Center
Z06 C5 Z06 Frequently Asked Questions(FAQ) - CorvetteForum - Chevrolet Corvette Forum Discussion
Z06 ***Build Date/VIN Analysis of LS6 Valve Spring Failures*** - CorvetteForum - Chevrolet Corvette Forum Discussion
Old 10-06-2022, 08:14 AM
4XLR8N
Pro Mechanic
4XLR8N's Avatar
Received 1,696 Likes on 1,241 Posts
Welcome to the asylum...
Old 10-06-2022, 09:24 AM
rrwirsi
rrwirsi's Avatar
Received 1,242 Likes on 790 Posts
Just a cautionary safety comment. If you do the in garage test for gas smell, do not close the garage door. Years back a neighbor had a gas tank leak that he thought was fixed. Brought the car home, parked it in the garage and closed the door. The next morning apparently he opened the house door and smelled gas and hit the light/or garage opener and BOOM! Leveled the whole house, killed him and his wife.
Old 10-06-2022, 09:31 AM
Sojourner
Sojourner's Avatar
What is the purpose of this post? Seems like a lot of fear mongering going on...I called C&S Corvettes and they have never heard of the fuel crossover tube issue. Not that it means it isn't a potential issue, but its certainly not common or they would know about it. I don't smell any fuel. This car sat in the garage of the guy I bought it from for 17 years and he never smelled fuel.
What should I do at this point? Other than filling it up and smelling around for fumes, can I inspect anything?
Old 10-06-2022, 09:48 AM
rrwirsi
rrwirsi's Avatar
Purpose? Just trying to save your life. But go ahead, do the gas test smell with the garage door down and if you smell gas, turn on the light and hit the opener.
To I bought my first Corvette!
Old 10-06-2022, 11:44 AM
Support Corvetteforum!
Received 19,989 Likes on 14,404 Posts
'20-'21-'22-'23-'24
You sure found a great looking, low mileage Z06. Congrats and hope you get many trouble free miles from the car.
Old 10-06-2022, 01:04 PM
MWWarlord
MWWarlord's Avatar
Received 3,113 Likes on 1,940 Posts
St. Jude Donor '21-'22
Congrats on your purchase! It looks like a great car. Good advice on tightening the oil pan to spec, cleaning, and then check for leak. So as best as I have been able to gather there was an issue with some of the '04 crossover tubes, as well as an issue with the gas tanks themselves. This was DEFINITAELY a real thing. GM avoided doing an official recall for this issue by adding a 10 year warranty specifically on the gas tank and crossover tube. I have an '04, and didn't know about this issue when I bought the car. My first house didn't have a garage, and I didn't really notice an issue until over a year later when I pulled it into my parent's garage to do some work on it during the winter. The gas smell was VERY obvious (my parents could even smell it inside the house). Unfortunately, it was just past the 10 year limit. I ended up having to get the tank replaced. This is a VERY expensive repair. With that said, you've already bought the car. I can tell you from experience, if this leak occurs, you will know it immediately once the car is in a garage. Based on your pictures, it seems like you likely keep it in a garage. As I said, the smell is immediately VERY obvious, so if you don't smell anything, you're fine. There is no leak. It is something that you want to keep an eye on. If you ever start to smell gas, open the garage. Wait for the garage to air out, and then take the car outside. If a leak occurs, you'll want to get it repaired as soon as possible. However, as long as it smells okay, I wouldn't worry about it.
You should check the date code on the tires. If they are over 6 years old, they need to be replaced regardless of the tread on the tire. It is very hard to find tires in stock sizes for the Z06. It is okay to go 1 size up or down in order to find tires that fit. Let us know if you have any more questions. Don't freak out about the gas thing. Enjoy the car!
Also, don't forget to SAVE THE WAVE!!
Old 10-06-2022, 06:56 PM
I’m Z one
I’m Z one's Avatar
Default Here is the (expired) TSB
https://www.tsbsearch.com/Chevrolet/10150
Quick Reply: I bought my first Corvette!
