Wideband Wiring...
![](/forums/images/ranks/500-1000.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
For those of you using a wideband controller, where did you get your power/grounds. I am using the LC-1 and it seems to be very particular where to ground and get power. I keep getting a full lean error when i crank the car, but if i just turn the key on, it will go through its heating cycle and display a value.
Im guessing im having this problem because the power is not constant while cranking, i spliced out of fuse#22
