500rwhp, Z06, 10 second 1/4 mile? (What do you run with your heads and cam setups?)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
If Chris at ECS is nearby then you should talk to him about a more aggressive H/C setup--why a 115 lsa on your cam, the lift and duration sound good but large lsa I wonder, to get 500rwhp NA out of 346ci you will need the FAST 90mm intake and a 90mm TB, probably 1 7/8" kooks, a 3" exhaust system will help, a good set of stage 3 heads that will honestly flow over 330crm--I agree with all the statements on your drive train parts as well they will not hold up under a hard launch--if you can put a 16" ccw drag package thet will take a good bit off the clock--like some of the post say 10's do not require that much power but the setup is what counts, drag package 410 or 390 rear gear, HD rear end parts and tranny brace, the short times will have to be in the 1.5s and that will play hell on your drive line--you will probably come to the conclusion after breaking a lot of things that the irs based c5 is not a drag car and without back halfing the car you will never have the piece of mind that you will be driving it home, and back halfing the car will deff take away alot of the street ability and handling that make it a sports car--
![](/forums/images/ranks/100-500.gif)
Yeah I've been changing alot of my plans recently becuase of funding. IF I'm gonna do something im gonna do it right. For now im gonna do a cam only with all the bolt ons minus the intake manifold and TB. I have an LS6 intake and manifold so it should be good for now.
![](/forums/images/ranks/11k.gif)
Location: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
![](https://www.corvetteforum.com/forums/images/ranks/cf20.jpg)
Originally Posted by new vetter
You don't sound very serious about 10's........
![*****](https://www.corvetteforum.com/forums/images/smilies/willy_nilly.gif)
![Ack!](https://www.corvetteforum.com/forums/images/smilies/ack2.gif)
![Leaving](https://www.corvetteforum.com/forums/images/smilies/leaving.gif)
