Anyone One Know How Big Of Wheel Spacers Do I Use?
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
I have a 99 vette and i bought the OEM rims and tire off a C6. they have not got ot me yet but does anyone know how big of spacers i need to buy to get a flush look? i herd they sit in too far because the offset, and im hoping to get the spacers and the wheels at the same time..
thanks for your help
aaron
aaron
![](/forums/images/ranks/2k-3k.gif)
The offset difference is 14mm (79mm vs. 65mm). Subtract 6mm (1/4 in)from the 14mm for the added C6 wheel width (1/2 inch wider divided by 2). The new wheels outer edge will be inboard by about 8mm or about 3/8 inch.
![](/forums/images/ranks/1k-2k.gif)
![](https://www.corvetteforum.com/forums/images/ranks/cf15.jpg)
I recently tried a set of C6 tires and wheels on my 99 Vette. I was expecting to need spacers but, to my surprise, they fit without a spacer. However, the rear tires sat really close to the wheel wells. Actually, a 5-8 mm spacer is probably all you would need for added insurance.
![](/forums/images/ranks/100-500.gif)
I did this over a year ago....don't use spacers. You need to buy a pair of adapters...big difference. The adapters bolt to your existing spindle and provide you with studs that are the right length. E-bay has a page or two of 'em. Search for "corvette wheel adapters". Like the guys are saying, some don't need anything, but it IS a tight fit. I went with 1" aluminum adapters...The fit is great. Durable too, I've 508HP to the rear wheels and they haven't come off yet....
![Cheers!](https://www.corvetteforum.com/forums/images/smilies/cheers2.gif)
