Part # Help Needed...
...I'm rebuilding a theft recovery 01Zapparently there is a splash shield that i am missing and cannot find the part # for.
It is held to the pass. side A pillar(behind the fender) by 2 small screws.I think it is to protect the ECM from moisture-the part # may be on it.Spent about 1/2 hour at the dealer looking for it but no luck.
Dominic
Dominic
Dominic
Dominic
CATEGORY: All
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $57.26
OUR PRICE: $35.12
It is held to the pass. side A pillar(behind the fender) by 2 small screws. I think it is to protect the ECM from moisture-the part # may be on it.Spent about 1/2 hour at the dealer looking for it but no luck.
Dominic
Dominic
ChopperLoco: Post a picture or give a more detailed description.
Same one I looked at too Ed and can't find anything like what he's describing. Especially something fastened by "two screws" and "held to the pass. side A pillar". I even looked at the PCM mounting location and didn't find anything there either.
I'm thinking this one is going to have to have a picture.
Thanks guys...
...I think i've seen all the GM parts pics.,including the one above-but don't see the part I'm looking for...keep in mind i've never actually seen the part i'm looking for,I was told about it from a friend when i told him of these two fine thread screws(7mm head) in the pass. side A pillar in between the two door hinges and hadn't any part to go there!
Dominic
Dominic
Dominic
Dominic
GM part # 10188042
If you have access to the GM parts list. look in: Group 9, pg 4J2, part #6.
When you open the door and look in the hinge area, you cannot see the entire tank; just the rear part that fastens to the A-pillar is visible. Access to it is normally behind the wheel-well and under the battery.
HTH
Dominic
Dominic
BTW with no HVAC, be sure to cap off the small vacuum port on the backside of your intake manifold. There is a vacuum fitting (small 1/8" black nylon tube) there that goes directly to this vacuum tank that we have been speaking of.
