HUD Display Falling...
![](/forums/images/ranks/7k-10k.gif)
Received 1,195 Likes
St. Jude Donor '15
![](https://www.corvetteforum.com/forums/images/ranks/cf15.jpg)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Look in the "DIY" post that is a sticky. There's a post in there on the HUD install but you'll be able to see the steps for removing the dash and fixing this. If I remember correctly it's a mount that tends to break or come lose or something. After you get it apart, fixing it should be pretty easy/obvious.
http://forums.corvetteforum.com/c5-t...th-pics-3.html
Post #48
If you use the advanced search you can find some information on how to repair the unit.
This link may help.
http://forums.corvetteforum.com/c5-t...y-too-low.html
Mine needs to be fixed also but I won't stop driving it long enough for the fix.
Good Luck with the repair.
Boulty
Post #48
This link may help.
Boulty
