A COMPREHENSIVE FAQ: The Tick Performance C5 Adjustable Clutch Master Cylinder Kit
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Hi there again Joey. I did ended up rebuilding my transmission again, the builder said that I was not fully disengage for third gear, which cracked my synchro. Due to the restriction in the lines, it would not fully disengage my pressure when I did have it pressed out.
I ended up making my on hydraulic line (complete) from the master to the slave. There were several restrictions I found in the oem system. The orifice hole for the master and slave were 1/8 inch in diameter. The restrictions in the lines were 1/16 inch in diameter. I took some pictures to show what it looks like.
![](http://i168.photobucket.com/albums/u167/wanttospeed/102_3129.jpg)
I drilled out one hole to 1/8 inch. The other is stock (1/16 inch). This is at the slave.
![](http://i168.photobucket.com/albums/u167/wanttospeed/102_3128.jpg)
![](http://i168.photobucket.com/albums/u167/wanttospeed/IMG_0008.jpg)
Of course to drill that restriction going into the slave on the vettes, the transmission would have to come out. If its out a new slave should probably be installed also. Hopefully the unrestricted line will help your transmission issues.
![Smile](https://www.corvetteforum.com/forums/images/smilies/smile5.gif)
![](/forums/images/ranks/500-1000.gif)
funny I find this. I too am having problems shifting quickly at high rpms... and now that I read this I realize that my clutch catches within the first inch of me letting up on the clutch pedal. Starting to think I need the tick.
![](/forums/images/ranks/3k-4k.gif)
St. Jude Donor '08-'09-'10
Those restrictions are the hard evidence that markc5 was looking for earlier in this thread concearning gm's deliberate attempts to weaken the hydraulic system. Thier obvious thinking was to restrict the fluid flow so that it wouldn't return to the master/resevoir any faster than the restriction would let it.
As you have correctly stated, the restriction will slow the release of the slave but would in no way I can see cause an inability to shift gears which is what it appears most buy your cylinder to resolve.
Again you are attaching intent to a design with no evidence or supporting documentation.
![](/forums/images/ranks/2k-3k.gif)
You can modify the stock master cylinder and make it adjustable without having to replace it with an aftermarket unit.
http://forums.corvetteforum.com/c5-t...ustable+master
Aftermarket suppliers such as yourself which puposely skew technical facts for the purpose of selling your products are successful only because most individuals in this hobby do not take the time to research and understand what they are buying.
I suggest you TICK sycophants do some research before dumping hundreds of dollars on a piece of equipment you may not need.
![](/forums/images/ranks/100-500.gif)
My 99 corvette would not shift at all at high RPM's and today I just installed the tick and the car drives great now. I can shift at high RPM's now, its like driving a differant car. I myself like the idea of just replacing a part and knowing it's going to work. I don't like the idea of going thru all that work to change something out without knowing it going to fix the problem. This is a sts twin turbo car and it sucked not being able to shift fast.
+1 for the Tick Master Cylinder
I put one in my C5 months ago and it drives so much better now. Wish this had been on the market years ago. This is an absolute must for anyone that drives their manual C5 hard.
The "intent" you speak of was for the purpose of slowing down the release time (by miliseconds) of the clutch when dumping it to reduce shock to the drive train thus improving drive train reliability.
![Yes Nod](https://www.corvetteforum.com/forums/images/smilies/yesnod.gif)
![](/forums/images/ranks/11k.gif)
The Tick master worked for me and alot of others with the same problem. (car would not shift at high RPM) I'm not saying it's right for everyone, but high horsepower cars with aftermarket clutches really do need one. The aftermarket modified MC's that are actually modified stockers offer adjustability, but don't move enough fluid to cure the high rpm shifting problem. The TIck MC cures it and the adjustability is just an added bonus. ![Yes Nod](https://www.corvetteforum.com/forums/images/smilies/yesnod.gif)
![I Agree!](https://www.corvetteforum.com/forums/images/smilies/iagree.gif)
After installing my TICK, I can now make those high rpm shifts and the pedal no longer stays on the floor nor do I have high rpm shift refusal like I did before.
The TICK unit continues to be sold and is successful for one reason. It works for the applications for which it was designed. If it didn't, I guarantee the entire Corvette, F-Body and GTO community would have been screaming long before now.
Add me to the list of happy Tick Performance customers. As said, the unit works for what is was deisgned for. And to top it off, Tick cusotmer service was great. Joey went out of his way to help me on not one, but two occasions. One during install, and one with helping me get the adjustment right. Cant ask for much more than that!
![](/forums/images/ranks/1k-2k.gif)
Are these still made and sold? The website no longer carries them
![Frown](https://www.corvetteforum.com/forums/images/smilies/frown5.gif)
#33
