Changing AC Belt and tensioner.
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
I just went through this. I changed both the tensioner and idler. It's definitely easier to get to from the bottom. I found that a swivel head socket helped. It's also handy to have someone able to hold it in place from the top when reinstalling. Overall wasn't that bad of a job though.
LeoLivinLife (07-04-2020)
I don't think the AC belt goes near the smooth bell-like water pump pulley. I think it's routed around the rear harmonic balancer track, above the tensioner pulley, around the AC pump, then below the idler pulley. Froggy has a pretty good you tube video on installing the belt. He uses tape to secure the belt to the harmonic balancer, which is what I did as well. A new belt is extra stiff and it tends to come out of the harmonic balancer track when you try to put it around the AC pump.
![](/forums/images/ranks/500-1000.gif)
The biggest pain in changing out my A/C belt is the A/C lines that are n the way on my '03 coupe. Had to use some rope to get them tied out of the way a bit to get a open end wrench on the tensioner nut.
