valve cover oil leak
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
my 2000 with 155k miles has some drops of oil oozing from the passenger side valve cover gasket ....how do i remove and replace this gasket ??? thanks in advance...new york nick
![](/forums/images/ranks/500-1000.gif)
The gasket is rubber and sits in a groove in the valve cover. Remove it and replace with a new one. No sealant of any type needed.
If you are asking how to remove the cover, there are many threads on here that explain the process. Pretty simple. Remove the frc, coil packs etc. I'm sure someone will chime in with exact details.
![](/forums/images/ranks/3k-4k.gif)
I did mine a couple of weeks ago pretty easy just remember where all the hoses go back too, torque spec for the valve cover bolts is 15lbs.
gonna change my intake gaskets and lifter vally gasket also i'll take a bunch of pics..!
![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
![](https://www.corvetteforum.com/forums/images/ranks/veteran_navy.png)
Received 20,037 Likes
'20-'21-'22-'23-'24
![](https://www.corvetteforum.com/forums/images/ranks/cf20.jpg)
![](https://www.corvetteforum.com/forums/images/ranks/cf-stjude20.jpg)
Moved to C5 Tech.
