How-To repair EBCM avoiding costly repairs through ABSfixer or Fleabay
![](/forums/images/ranks/11k.gif)
![](https://www.corvetteforum.com/forums/images/ranks/veteran_army.png)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
I will get this added to the DIY sticky thread
![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
Lifsgrt (06-02-2024)
![](/forums/images/ranks/5k-6k.gif)
Well... It must say something for things made in Mexico: They're built to not come apart. I cannot get that damn back panel off. Unscrewed the 4 t-20 screws. Removed the silicon from the hole. Now I can't get the plate off...
I even tried using a steel pin and table vice, and it just bent the pin. Literally won't come off. LOL
Any suggestions?
Any suggestions?
![](https://www.corvetteforum.com/forums/images/ranks/veteran_navy.png)
Received 2,191 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
![](https://www.corvetteforum.com/forums/images/ranks/cf20.jpg)
I just used 5-6 flat blade screwdrivers and wedged them in between the cover and housing. Just dont go too deep. Once you get it started, it will break loose. Just wedge evenly.
BC
BC
![](/forums/images/ranks/3k-4k.gif)
Location: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
![](https://www.corvetteforum.com/forums/images/ranks/cf10.jpg)
I always suspected it would be an easy fix. Add the door lock switches to things with bad solder joints.
#36
![Rock](https://www.corvetteforum.com/forums/images/smilies/rock.gif)
#37
all I did was use the hole on the back where he used a crew put a punch inside and tapped it with a hammer theres a lip u need to get under as soon as u do it will pop off
#39
