Wideband 02 Sensor, where to install and route with headers?
![](/forums/images/ranks/3k-4k.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
I have an LC-1 Wideband that I used to simulate the primary 02 sensor on the passenger side when I ran stock manifolds. I have recently installed long tubes and would like to put a wideband in to properly tune it. Does anyone have any pictures, know of a write up or can offer some advice in where in the long tubes is a good spot to drill and weld the 02 bung as well as how you routed the wires inside the car? I don't need to keep the WB installed since I have the narrowband back into place. I just need to install it for tuning only.
![](/forums/images/ranks/5k-6k.gif)
![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
![](/forums/images/ranks/11k.gif)
Did this several years back but it still works perfectly. I had to replace the sensor and reroute the wiring once when it loosened up and melted when it touched the header. I now have it secured nicely with 1200 deg. F shielding on the cable.
http://redshift.homestead.com/WBO2.html
