New LS2 402 - Cylinder wall toast? Pics included.
![](/forums/images/ranks/100-500.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
I posted a couple weeks ago about an LS2 402 I bought still in the crate. Since it had some rust forming and was not sealed up, with the advice of folks on the forum I started tearing down the motor tonight to begin the cleaning process. Everything went great and I was all proud, and while taking photos, I noticed this little crack at the bottom of #8:
![](http://i646.photobucket.com/albums/uu188/jmmowrer/LS2%20402%20Build/th_100_0180.jpg)
Is this something that is expected or is this block done for?
Thanks!
Jake
Thanks!
Jake
I do not think it is done for, but I can not say for sure. It could probably be welded and re-honed to be just fine.
Is the crack actually on the wall or is it on the edge of the deck? Kind of hard to tell with the reflecting light and angle.
![](/forums/images/ranks/7k-10k.gif)
If it's in the liner, take it to a machine shop and have them MagnaFlux it to make sure it's a crack and not a scratch. Even if it is a crack you can have a VERY GOOD machine shop replace the liner.
Former Vendor
That looks like a crack ... have the block pressure checked
If it is a crack I suggest re-sleeving the entire block with Darton dry sleeves -- you will gain strength and reliability as the new liners are .625 longer -the proper he proper length to support your 4" stroke - and of superior material.
Thanks!
Jake
Thanks!
Jake
Thanks for all the responses, this is very helpful and makes me feel better considering this block has never even been fired up (all the assembly lube is still in place), I was pretty ticked off when I found it
The crack is on the very edge between the cylinder and the deck where it starts curving. I'll take it to the machine shop and have them check it out. Should I bring pistons and crank too at this point in case they have to do major work and rebalance? This is my first machine shop visit so any guidance is appreciated!
Thanks,
Jake
![Smile](https://www.corvetteforum.com/forums/images/smilies/smile5.gif)
Thanks,
Jake
I haven't messed with any of the aluminum block engines but a cylinder wall is a cylinder wall and that one doesn't have the proper cross hatch for the rings to seat. Find someone who is familiar with the LS platform and have him check it out. Even if the block/sleeve is ok it needs to be honed right.
