Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
- How to Install Intake Manifold
Step by step instructions for do-it-yourselfers.
Intake Manifold removal question?
![](/forums/images/ranks/500-1000.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Hello,
I need to replace the oil pressure sender unit and think I'm gonna go the intake manifold removal route. My question is this.... I have noticed on the "tutorials" i've seen on removing the intake manifold that the manifold gets unbolted and slid forward then returned and rebolted once new sender is in place. No mention as to a gasket replacement under the manifold. Is it ok to just replace the manifold without a new gasket following recommended torque specs??? Or is there a new gasket that I need to purchase to replace?
Here is a link to the "tutorial" I was using: Found through the tech DIY sticky on here.
http://www.vette747.com/index.php/en...intake-removal
Thanks!!
Tyler
Thanks!!
Tyler
![Flag](https://www.corvetteforum.com/forums/images/smilies/patriot.gif)
![](/forums/images/ranks/4k-5k.gif)
Gasket replacement is normally not needed.
![Name: 375-MS92438.jpg
Size: 6.8 KB](https://www.corvetteforum.com/forums/attachments/c5-tech/48186740d1501790797-intake-manifold-removal-question-375-ms92438.jpg)
![](/forums/images/ranks/1k-2k.gif)
I would certainly replace the gaskets if your car has some age on it. They are only $20 or so. Seems like good maintenance to me. When I pulled the intake off my engine I got the gaskets at O'Reilys.
Make sure when you replace them that you run your fingers over them several times to seat them quite well. I didn't do it right the first time.
Good luck.
Good luck.
Well, I took mine off to put a dam of gasket maker around the plugs for the knock sensors while I was in there, keeps the water out of the knock sensors if the engine ever gets wet-there was a TSB for it. I used new gaskets out of habit.
I would replace any gasket if the part is removed. Its cheap insurance I think.
I have a tutorial on intake removal on my web site under the section at the bottom (Fast 92 Intake install).
www.ToqueZ06.com
Toque
www.ToqueZ06.com
Toque
I would add that you will probably need to clean the oil out of the intake while you got it off. You can pull the MAP sensor off the back along with the TB and wash it out with soap and water.
![I Agree!](https://www.corvetteforum.com/forums/images/smilies/iagree.gif)
It makes a great opportunity to clean out the intake when it's removed.
If soap and water doesn't remove all the oil, use some engine degreaser and rinse with water.
It's always a good idea to replace gaskets when re-assembling.
That said, I haven't replaced the gaskets on any of my intake manifold pulls lately and everything has been fine.
I never take my own advice or any other good advice.
![](/forums/images/ranks/3k-4k.gif)
St. Jude Donor '08
![](https://www.corvetteforum.com/forums/images/ranks/cf10.jpg)
my car had 60k miles on it and the gaskets needed to be replaced. as noted, do the TSB for the knock sensors since your already there. take the sensor off the manifold, take it to a car wash and pressure wash the **** out of it. in my opinion, a little soapy water wont do anything. i used simple green and about $4 at the car wash to get my manifold acceptably clean.
there is also a write up on LS1 tech that shows R&R without disconnecting the fuel lines. I did it this way and didnt spill any gas. I actually followed a couple of write ups and picked the parts I like best on each. I think the ls1 write up has the torque and order to install the manifold.
its pretty straight forward, good luck
![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
Going to be putting my 02 z06 intake on the wife's 99 coupe. Any advice other than what has already been given here? Also putting Kooks lt and catted X pipe on.
![](/forums/images/ranks/2k-3k.gif)
![](/forums/images/ranks/11k.gif)
You will likely find sand all over the place when you remove the intake. Try to get in there with a vacuum to get anything that is loose so it doesn't inadvertently fall into the head intake port.
How about cleaning up the intake a bit with a dremmel tool? what should I look for? Do I just try to smooth around the inner edges of the openings? Thanks for the tips too.
I found removing the Intake to be a little harder than I thought it would be. Maybe because I have the LS6 intake rather than the LS1. After about 7 hours I have most of it back together, I'll finish it up tomorrow.
I did this because of the oil pressure sending unit going out at 65,000 miles on a 1999 C5.
I sent to NAPA and got the brass replacement unit as instructed and it was even the less expensive one !! I also got the intake gasket set.
The old gaskets looked ok, but I replaced them anyways and the new Fel Pro gaskets did look like they were a little more "Proud" than the old ones ... also the old foam rubber was badly in need of replacement.
I installed the new Oil Pressure sending unit, no problem, it's 27mm BTW, but a 1 and 1/16 socket will work too, deep socket of course.
Installing the manifold was the hardest part as I found it IMPOSSIBLE (let me repeat, Not possible) to attach the small hose and the big hose and the electrical connector at the back of the manifold .... I couldn't do it.
So I attached the big hose before I installed the manifold, then snaked the hose around behind everything and towards the brake booster. Then I could just barley attach the small hose and lastly the electrical connector. Very hard, just no room.
I'll finish up tomorrow.
![*****](https://www.corvetteforum.com/forums/images/smilies/willy_nilly.gif)
1/4 mile/AutoX
Very good idea !! Why didn't I think of that !!?? I wanted to remote mount my oil pressure sending unit, but I didn't have anything to do that with, so I just left it where it was .... off I go to finish up.
Done, all tools put away, test drive complete, everything looks good. Oil pressure normal
Took me about 8 hours total between 2 days. I may be slow but I am careful and I did do a couple other things, so that's ok. Now I just need to turn that "Check Engine" light off !!
I search for that now .... car is outside waiting to be washed now.
1/4 mile/AutoX
