T56 Rebuild
![](/forums/images/ranks/2k-3k.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Whats up guys, lately i been having a problem with 3rd and 5th gear.. During a WOT pull 3rd gear doesnt like to go in most of the time...I recently changed out the clutch for a twin disk and the issue is still happening. My problem with 5th gear is that not all the time but sometimes it grinds going into gear..this happens during normal driving.
Last year the trans was replaced underwarranty, so theres not too many miles on this trans.. i would guess about 10k or less.
any opinions/ideas/tips on what is happening n what i need to upgrade would be great..
Supporting Vendor
St. Jude Donor '08-'09-'10-'11-'12, '14-'15-'16-'17-'18
![](https://www.corvetteforum.com/forums/images/ranks/cf10.jpg)
When the transmission was replaced under warranty, was it a new GM unit that was installed?
If you still have issues after the shifter aligment, try changing the fluid. If that doesn't help, I would have the tranmission removed and have it looked at.
