c6 z06 19x12 fitment with pics
It's interesting how much variance there is in tires sold as the same size.
St. Jude Donor '15
Manufacturers decide what percent ratio of section width to tread width they want to use. It ranges from 80 to 98 percent.
This why one tire looks wider than another of the same section width. That first number of the tire size is the measurement from sidewall to sidewall.
St. Jude Donor '15
An update. With the car lowered, they did rub the inner fender. So I raised the car up, went with 325 / 30-19 tires, added a 5/16 spacer and realigned it.
St. Jude Donor '15
Another update. Raised the car up another 1/2" because tires would hit on a large bump. Took the spacers off and no rubbing of inner fenderwell. Car is back to stock height.
St. Jude Donor '15
To take care of the slight rub on the inside I put these on. They were from my old 3rd gen fbody trans am. Factory gm 1/8" thick steel spacers. We're put on the rear with drum brakes to help clear the wheels.
