Kenwood Stereo Losing Bass
![](/forums/images/ranks/100-500.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
I have a Kenwood 4707S and a PAC bose integration wiring kit, as well as a powered subwoofer. Everything works great when I start the car and sounds amazing. However, after driving, sometimes for 20 minutes or so, and sometimes it works fine for a couple hours, but frequently it will lose all bass response. The subs in the doors and the powered sub both go off at the same time. The radio keeps playing but it's all tweeters. Back and front speaker still work.
Any suggestions on where I should start on this issue? I opened a case with Kenwood as well.
I thought at first it might be overheating, but I would think the whole stereo would turn off in that case. This also happened before I installed the powered subwoofer, so I know that's not the issue. And the powered sub is connected directly to the output jack of the Kenwood, so I can't figure out why it's dropping both the PAC and the Sub at the same time.
There is only one common connection between the two - the "power control" blue wire. I've confirmed that has a solid connection. And the sub is grounded completely separately from the PAC and Kenwood.
Any suggestions?
Any suggestions?
How do you have everything wired? I'm assuming your aftermarket sub is hooked up to the sub RCA jack on the Kenwood deck, and you're sending full-range to the doors. Correct? Did you do the install or was it a shop?
Yes, the light on the sub goes off when this happens. It's like the stereo just stopped sending a signal.
![](/forums/images/ranks/7k-10k.gif)
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
![](https://www.corvetteforum.com/forums/images/ranks/cf15.jpg)
Sounds like an issue with the deck itself or something is overheating and thermally shutting off the accessory power.
Since door and external subs are dying together, then you know the issue is with the blue wire power just timing out.
Not sure really why you would need both. Typically you use either or. Try disconnecting the door subs and see if the system survives on just external sub.
All you need is to disconnect the white connector behind the deck. This feeds the subs.
This isn't a thermal issue. This is something going wonky with the remote out on the deck. Could be an intermittent short, or a shoddy connection. But does explain your issue.
An easy fix would be to take the wires connected to the blue/white (one is turning on the base amps, the other is going to your aftermarket sub) and hook them up to the red wire. If the issue persists it's a connection issue somewhere, if it goes away its a radio issue.
rellz614 (10-21-2022)
I've decided that I'm going to hook just my powered sub to the red wire and see what happens. If the powered sub works but the bose integration stops then I know 100% it's the blue wire. Clarification - if I connect to the red wire, can I leave it like that permanently? I guess I don't really know the difference about leaving it connected permanently to the red instead of blue/white - what are the tradeoffs?
