How to remove the rear view mirror?
Old 07-06-2004, 06:33 PM
Tony @ MPH
Supporting Vendor
Support Corvetteforum!
Tony @ MPH's Avatar
Default How to remove the rear view mirror?
Is there some special trick or is it just a matter of prying carefully?
Old 07-06-2004, 06:42 PM
spdnman
spdnman's Avatar
Default Re: How to remove the rear view mirror? (diynoob)
Remove screw/ bolt and slide the mirror up. Also, first disconnect the wire harness.
Old 06-17-2018, 05:31 PM
JOHN RICCIARDI
JOHN RICCIARDI's Avatar
There is no visible screrw holding it !!!!
Old 06-17-2018, 07:04 PM
mnotx
mnotx's Avatar
If you are talking about the windshield mounted rearview mirror, and there are no visible screws, take a flashlight and look at the mount from the outside through the windshield. You may have the mirror mount that consists of a strong, snap attachment. Hard to explain, but if you look at it you will understand it completely. There two tabs that need to be depressed and the mirror will slide right off the mount. I found the easiest way was to take a small vice grip and adjust it so it closes just enough on the tabs to hold them down enough to slide the mirror.
It will make sense once you look at it.
SpeedRacerMach (10-25-2018)
Old 06-17-2018, 07:45 PM
JOHN RICCIARDI
Default mnotx
THANK YOU i HAVE A FEELING THIS IS GOING TO WORK; THANKS AGAIN MY FRIEND
To How to remove the rear view mirror?
Quick Reply: How to remove the rear view mirror?
