What's the widest tire I can put on my OEM rear wheel w/out sticking out or tubbing?
![](/forums/images/ranks/1k-2k.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
275/40 -18 inches = Stock
I want to buy the widest rear tire that will safely fit on my car. Not wheels, just big tires to mount to the stock rear wheels.
What Nitto or BF G are you guys running (285/35 ??) on stock rear rims for maximun traction at the track?
Is there such a tire ?
I do not want the tire to stick out.
Can changing profile/width affect my speedometer ?
Any help would be appreciated - Thanks.
![](/forums/images/ranks/3k-4k.gif)
![](https://www.corvetteforum.com/forums/images/ranks/veteran_coast_guard.png)
There are several guys running 295/35/18's on stock C5 rims. I am probably going to do the same very soon. It is 20mm wider than stock, but since the sidewall is a 35 instead of a 40, the tire is actually still about .6" shorter in height than the stock tire.
![](/forums/images/ranks/500-1000.gif)
![](https://www.corvetteforum.com/forums/images/ranks/cf20.jpg)
Originally Posted by steve badalamenti
I'm running TOYO PROXES S/T 295-45-18 's on the rear....
had them on for about 35k miles....get compliments all the time.
![Ack!](https://www.corvetteforum.com/forums/images/smilies/ack2.gif)
![](/forums/images/ranks/11k.gif)
I went through all this a few weeks ago. I ended up deciding on the 285 Nitto DR's for the back and 245 Nittos ( non-DR's ) for the front. Discount Tire cautioned me about running greater than a 285 on my rims. I'm sure it can be done, but, I felt more comfortable sticking closer to stick sizes. Also note that tire price increases significantly with size.
FWIW, the Discount Tire at 16 and Van **** that just opened is offering an additional $25 off as part of their Grand Opening.
Mark
Mark
Mark, do you recall exactly why discount cautioned against larger than 285's ? What is the profile on the Nitto 305 ?
Thanks for the input fellas, will this affect my speedo ?
![](/forums/images/ranks/7k-10k.gif)
Originally Posted by ramcharger
That's a truck tire. ![Ack!](https://www.corvetteforum.com/forums/images/smilies/ack2.gif)
![](http://www.toyo.com/tires/tire_lines/sports_car/tires/2.gif)
![](http://www.toyo.com/tires/tire_lines/images/titles/proxes_t1s.gif)
![Leaving](https://www.corvetteforum.com/forums/images/smilies/leaving.gif)
I have a 03 zo6 and want to run the 295/45 18 on the rear and want to make sure they will fit with no problems as you ran on yours, your input would be very help full, thanks
