clutch sticking to the floor
4th Gear
![](/forums/images/ranks/100-500.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
What are the options to a clutch sticking to the floor? (If any)
I’m New owner to c5 corvette 1998. I read an early thread about the zo6 clutch is this the problem. If so who can do the job in long island N.Y.
thanks for any help
thanks for any help
![](/forums/images/ranks/5k-6k.gif)
I got rid of my sticky clutch by
1. replacing the slave with a 2002- present.
2.do the drill mod
3. used high temp fluid
4. wrapped the slave with headerheat wrap.
After all that the clutch never stuck again.
2.do the drill mod
![](/forums/images/ranks/2k-3k.gif)
2.do the drill mod
2.do the drill mod
![I Agree!](https://www.corvetteforum.com/forums/images/smilies/iagree.gif)
some must be luckier then others. I did the following w/ no help:
1. Wrapped master to slave line in high temp tape then slit a -8AN braided line and slid it over the line.
2. Put a z06 slave in
3. Put a z06 master in
4. bled system fully
5. Flushed system completely w/ High temp MOTUL racing fluid.
6. Did the drill mod
None got rid of the problem. Its in the clutch/pressure plate somewhere in my instance.
Dave
Dave
