The return of the complete C5 Clutch Install guide
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
My favorite quote:
"Remove the 4 nuts holding the cradle to the car (21mm I believe). NO IMPACT TOOLS.
Using impact tools can break the retaining rivet that prevents the large studs from rotating.
If you do this, you will have to remove your carpet, and cut an access hole in the floorpan of your car.
Not fun. Ask me how I know..."
Sorry dude, but I had to laugh! My knuckles bleed for you dude...
![ROFL](https://www.corvetteforum.com/forums/images/smilies/rofl.gif)
![](/forums/images/ranks/3k-4k.gif)
Having done this once myself, I would hazzard a guess that I could now do this replacement again in about 6 hours. I've got a lift and a lift trans jack, but could see someone doing it off jack stands in about 6-8 hours... Once you understand just what parts need to be disconnected on the rear suspension, it isn't that bad.
Mike
Mike
![](https://www.corvetteforum.com/forums/images/ranks/veteran_navy.png)
Received 2,191 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
![](https://www.corvetteforum.com/forums/images/ranks/cf20.jpg)
Thanks a million!
Bill C
Bill C
![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
Originally Posted by Patches
Awesome write-up, Dope. Excellent job and nice work on the swap out.
Thanks for taking the time and making the effort to post that tutorial.![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
![Cheers!](https://www.corvetteforum.com/forums/images/smilies/cheers2.gif)
Mike and I are swapping out my clutch this Saturday... if you feel like coaching or just watching and laughing come on by....
![](/forums/images/ranks/5k-6k.gif)
Originally Posted by pewter99
wow..great write up....pilot bearings
BTDT..
best quote of the article...![Greenie](https://www.corvetteforum.com/forums/images/smilies/smilielol5.gif)
Lubricate well, and hammer that sucker into the crank. When this doesn't work, grab progressively larger and larger hammers until that piece of crap is flush with the outside of the crank.
![Cussing face](https://www.corvetteforum.com/forums/images/smilies/cuss.gif)
![](/forums/images/ranks/2k-3k.gif)
Probably because this thread is 7 years old...and things change...
Go here:
http://www.cajundude.com/c5techhome.htm
and scroll down to Dopes writeup (save it as a Word doc.)
Go here:
#35
I must thank you, too! After checking out prices and time frame for others to do it, I looked up your tutorial and said to myself "I can do this." So my car's been on jackstands now while I'm changing the entire clutch system and doing some otherwork at the same time and everything's been going fine. Thank you, Dope!
If everything goes okay I should be back on the ground this weekend!!!!
#36
![](/forums/images/ranks/11k.gif)
Location: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
![](https://www.corvetteforum.com/forums/images/ranks/cf15.jpg)
Currently fighting with the GD'ed pilot bearing. I really wish they had used a larger bearing so you could get a good three-jaw puller in there and pull it out cleanly. Off to Home Depot to create the Dope super-duper bearing puller. ![Bang Head](https://www.corvetteforum.com/forums/images/smilies/banghead.gif)
Otherwise, Dope's instructions ahve been spot on!
#37
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I used a little bit of HEAT (propane torch ) to heat up the crank around the pilot bearing hole and warmed the crank to about 120 deg. Once it was heated, the standard rental tool from Autozone popped it right out!!
Be careful of the Welsh plug in the back of the crank and don't damage it.
#38
Corvette Cowboy
Great write up Dope thank You I have some input if you would like to add as I am in the final stages of the rebuild. It has been fun my 14 yr old Daughter has learned a lot about cars helping me.
Pops & Monkey
Pops & Monkey
#39
I just saw that this thread is still continuing. I previously posted that I recently was doing a clutch swap and using the "Dope" tutorial. Aside from the clutch swap I also disassembled my torque tube to check it out and also replaced an axle shaft seal, aside from other maintenance and cleaning of the underside while it was all apart. I was in no rush and took several weeks to get it done just working on it mainly on Sundays. The job was a total success and the car has driven perfectly from the moment the wheels once again touched the ground.
One helpful hint I discovered. There is a 3-finger puller tool for removing the pilot bearing. I believe it's a Snap-On tool. A friend of mine is a GM master tech and happens to have this tool in his toolbox. I was able to borrow it from him and it makes removing the pilot bearing alot easier. The three fingers actually fit inside the bearing. Just tighten and the bearing pulls out.
