Clutch fluid change - one year and 10K miles (pics)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Anyone have any thoughts on why the fluid gets so dark so quickly in our cars? The only sources I can think of would be moisture, heat, and contamination.
Moisture - I just bought some of the OEM fluid today, so I'm going to leave a small amount in an open container to see if ambient moisture is causing the color shift. If so, that means our seals are not very good. I kinda doubt it though.
Heat - if it's heat, our clutch must be putting out a lot of heat to be turning brake fluid dark so quickly. I have 1400 miles on my car (1.5 months old) and the fluid is already looking like iced tea.
Contamination - are there seals or bellows on the moving parts for the slave cylinder? Perhaps the dust from the clutch is getting on a sliding surface and being pulled into the system with each actuation. Forgive my ignorance, in that I am not familiar with how our slave cylinder works. I noticed that the vette slave cylinder does not look like slave cylinders on other cars that I haved owned. In my other cars, the slave cylinder would be external to the transmission housing and actuate an arm that engaged the clutch.
I'm just curious if anyone has determined the cause for all this headache.
![](/forums/images/ranks/11k.gif)
If it was that nasty, depending upon how often he drives it, I wouldn't even give it that long.
I'd take a look at it a couple days later and change it a couple days later. I'd pump that clutch pedal 10 or 20 times like he said to bring up all of the old clutch fluid still in the line
Brake fluid is cheap. I try to change mine about every week. Pretty much whenever I wash the car. The longest I have gone is about 3 weeks. I don't particularly care for the bulb turkey baster. Less control and a good chance to wind up eith brake fluid on your paint. Get a syringe that you can draw back the plunger on to draw it out.
I use a 60cc syringe and just draw it out with the syringe. Then draw up about another 60cc of new fluid and put it into the reservoir after cleaning the cap. Then pump the pedal. Takes less than 10 minutes.
By now, all of the clutch fluid in my line looks damn near brand new.
![](/forums/images/ranks/2k-3k.gif)
thank you for all your knowledge on this and many other subjects...
yours was, by far, the most informative and until it happened to me it was just in the back of my mind.... i could not remember your name at the time of this post.... please accept my apologies....
this place is great!!! so much info it makes my head spin at time... my tires too!!!!!
![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
![Cheers!](https://www.corvetteforum.com/forums/images/smilies/cheers2.gif)
Guyz please HELP.
So I was trying to flush the Clutch Fluid yesterday and when I went to Power Chevy in Irvine the guys at the service counter said that the the GM Part number in my Owner's manual was discontinued. In the owner's manual it calls out GM Part No. US 88958860.
He gave me a 16 ounce bottle of Hydraulics Clutch Fluid #12345347. Now this bottle is clearly marked clutch fluid and in the back it is marked 'DOT3 with friction modifiers'.
No one carries the old GM part number and on the forums, everyone seems to be using Prestone DOT-3 brake fluid. What is the deal here. Can I use the Fluid that was given to me by the Power Chevy dude?
http://paceperformance.com/index.asp...D&ProdID=91000
I just found this link. It says Super Dot-4. That is what is in the original manual. I think the guy gave me the wrong stuff. I put this into the reservoir. Should I get it out and then replace it with the Prestone Super Dot-4? Where do you get this stuff?
![](/forums/images/ranks/7k-10k.gif)
![](https://www.corvetteforum.com/forums/images/ranks/cf10.jpg)
Guyz please HELP.
I'll assume it's a C6, the Chevy spec for the the C6 clutch fluid is GM-branded Super DOT4 brake and clutch fluid. DOT3 they gave you is spec for C5s. Wouldn't put that in the C6.
So that parts guy is incorrect. Suggest trying a diff dealer. The GM Super DOT4 is made by Petosin and it's a very good fluid.
I'm using Prestone DOT4 Synthetic. Widely avail. But others would be fine too.
Here is a list of alternatives. Company that compiled the list doesn't sell brake fluid.
Ranger
![](/forums/images/ranks/4k-5k.gif)
Ranger
#33
But if the clutch fluid is black it ought to be cleaned up. So the guy you lend your car to that lacks your sense of self-restraint won't get pedal woes either when, out of ear shot, he hammers your car to redline through the gears.
![Smile](https://www.corvetteforum.com/forums/images/smilies/smile5.gif)
Ranger
#35
![](/forums/images/ranks/3k-4k.gif)
I flushed my clutch fluid reservior the other day using an entire 8.45 ounce bottle of GM Super DOT-4. Pumped the pedal a good 10 - 15 times between each fluid extraction. Fluid was originally black, became quite clear after the 8.45 ounce flush... not perfectly clear, but about 85% clear.
After about 100 miles, while not even thinking about it, I seemed to notice that my clutch pedal felt a bit "stiffer". Almost felt as if the pedal action was a tad higher, had a more firm solid feel. At first I was wondering why this would be, then I remembered that I had changed the clutch fluid!... so I don't think I was just imagining it. The difference isn't huge, but it is noticeable... and it's indeed an improvement.
After flushing in the 8.45 ounce of GM fluid, I took an 825 mile trip. Just returned yesterday and looked at the fluid... looks black again. So I plan to flush in one more 8.45 ounce bottle of Super DOT-4 and call it a season. I think at that point, especially since I do not drag race, the clutch system should be ok at least for another 6 months or so. The 825 mile trip should have circulated some of the remaining old fluid in the slave to the reservior so that I can flush the "rest" of it out today with the second bottle of DOT-4.
Will probably get on a schedule of flushing in two bottles of Super DOT-4 every spring and fall. This may not be an adequate schedule / procedure for those who drag race, but I'd think it would be fine for daily driver people who want their cars to run tip-top with minimal tinkering.
#38
Pardon my ignoranse (I don't have my '08 yet) but shouldn't there be a Bleed screw for the system down by the bellhousing somewhere? Other cars of similar design have this. That would certainly avoid using the large quantities of fluid it seems to take to clear the system..
#39
So the easy and accessible path is to keep the fluid clean via the reservoir.
I paid a shop for a full bleed....around $120 in 2001. That cost is what prompted me to focus on the reservoir path.
Ranger
#40
