Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: General How-Tos
- Corvette: How to Fix Popping Noise
Step by step instructions for do-it-yourselfers.
New Approach to Fixing Top Popping Noise
#421
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
I bought an '05 in October '13 with 56,000 miles and both tops were driving me crazy. I paid for the Dupont Krytox lubricant which helped a bit but not really as much as I hoped it would. The painted top was a now bit quieter than the clear but the clear top was almost unbearable whenever I decided to give it another go.
Finally found this thread while looking for fixes on interior creaks and moans (mostly from body flexing when entering my driveway or going over bumps - the dash sure has a lot of plastic that rubs together) and just tested it on the clear top over the roads I use every day. Not ONE pop or click or tick or squeak. I am amazed. So I installed the second set of clips on the painted top and, if I ever go back to it, I expect it to be nice and quiet too.
Amazingly simple and cheap. I hope it lasts!
Kevin
Kevin
#422
![](/forums/images/ranks/3k-4k.gif)
snip
..... So I installed the second set of clips on the painted top and, if I ever go back to it, I expect it to be nice and quiet too.
Kevin
snip
Kevin
The clips i installed on my 08 in Sep 2013 have worked perfect. I wonder why you decided to paint the clear top?
#423
Sorry for the confusion. I thought everyone referred to the body-colored top as "painted".
I might swap out the two tomorrow and drive around to see if the painted top is nice and quiet too. I hope so.
Kevin
#424
I just bought a 2012 GS and am having the noise problem (really bad). The dealer replaced the latches, did the lubrication, but that did not resolve the problem. We are now negotiating a new top. My gut tells me that is a dead end too.
Are the new latches a design change that will not respond to the e-clip fix or are they built differently? I haven't inspected the latches myself yet because I wanted to give them a chance to fix the problem themselves since I just bought the car.
Appreciate any opinions.
#425
I have an early 2008 with the old style latches and adding the e-clips really helped with the old style rollers. Your 2013 has the new latches unless someone installed an older top. If I was you, I would apply some shrink wrap on the two post and put new 0-rings over the shrink wrap. Give it a try... the price is cheap.
Dick
This is how I fixed mine but note I have the old style roller latches. The shrink wrap and o-rings may help yours
![](http://i1296.photobucket.com/albums/ag2/rmkriss/IMG_0004a_zps1118b9a0.jpeg)
#426
Since it doesn't look like the e-clips are an option with the new latches I will try the shrink wrap and all other potential fixes if I end up with the car because the dealership can't remedy the situation.
#427
![](https://www.corvetteforum.com/forums/images/ranks/veteran_army.png)
FWIW, this is the fix I have been using on my Centennial GS;
1. Remove the top
2. Use talcum powder lightly on the flat surface of the rubber gasket that meets the glass top, front and rear.
3. replace top
4. Squeak/pop gone......at lest until the next time the top is removed.
This has worked for the last 35K miles (2 1/2 years).
1. Remove the top
3. replace top
![Cheers!](https://www.corvetteforum.com/forums/images/smilies/cheers2.gif)
#428
Thanks hisvette.
I will try that along with all other remedies suggested here if I am forced to take the car back and accept the problem as my own. Since this was sold as a Certified Pre Owned car with a 12 month bumper to bumper warranty so I sort of feel that I need to let the dealership exhaust what should be their responsibilities first.
In some ways I want to take the car back and try these things myself but I'm afraid that could weaken my case if this turns into a legal battle.
I still would appreciate any helpful comments on fixes or courses of action if the dealership can't fix this or refuses to take it back.
#429
Hope this makes since, and sorry for long post. Good luck.
#430
Here's another good resource...
https://www.corvetteforum.com/how-to...g-noise-368671
joliett (04-03-2018)
