5/32 E-clip top repair
#41
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
It sounds like popcorn in my car when I drive over anything other than a glass smooth surface. I need to install some clips, lube and heat shrink. Do I just heat shrink over the rear posts on the roof panel?
#42
I later installed O-rings but noise got louder. So removed.
Will try shrink tubing on rear posts in a few weeks and see how that goes.
Good luck.
#43
![](/forums/images/ranks/4k-5k.gif)
Did you make sure all the handle and latch hardware bolts are tight? If the creaking is coming from the rear latch that can be adjusted. I did not use the o rings or shrink wrap, only e-clips and dielectric grease on all contact points.
#45
I have not tightened the front or rear latch mechanisms. I will give them a try before I try the shrink tubing. I have noticed that when I lift the rear hatch, there is a repeatable slight creaking sound. I have tightened the halo bolts, but that did not stop the noise. Doing one thing at a time allows one to see if and how much that fix helped. With only the e-clips installed, the remaining slight creaking seems to be coming from the rear passenger side. thanks for your suggestions.
